question about 3pt sprayers
/ question about 3pt sprayers #1
edgarrian
Brownsburg,IN
NA
Hello All,
I maybe in the market to get a 3 point sprayer for my tractor. It would be a category 1. I was wondering what brands most of you have used. Ill be using round up for weed control.
I don't really need a boom sprayer. Im assuming pumps hold up well when using round up as long as a guy flushes the system and correctly winterizes.
IM not looking to get a PTO driven sprayer as those are bit more expensive but would be nice. I can justify the extra costs.
Thanks for any suggestions
/ question about 3pt sprayers #3
I do not have experience with either in actual use, but I was looking at the same Fimco from TSC, and found this at Atwoods:
SMV Industries 4-Gallon 3-Point 5TN Sprayer
The frame is steel tubing (bolted not welded) with the tank bolted to this with some extra space on the frame. 40 gal would probably work fine, but I have also been looking at tow behind versions with 60-75 gallon as well, so the extra size intrigues me, though that may not matter for you.
/ question about 3pt sprayers #4
You can buy poly barrels cheap on CL. Pick the size you need. They come 15 gallons and up to 55 gallons. Then buy a 12VDC pump. I found one for $19 on ebay. Next, you'll nee some tubing, fittings and hose clamps. Next, you'll need a wand with valve and nozzle. All this can be had for less than $100.00. Mine was about $65.00.
I use mine for weed control, insecticide as well as spraying my fruit trees. Also, it can be used to spray car wash soap to clean the tractor.
DC 12V 7?W 13?PSI 6L/Min Water High Pressure Diaphragm Self Priming Water Pump 6??68512877? | eBay
5?+ Feet 85?15469 And/Or 85?15223 Fiber Reinforced Nylon / Plastic Hose 3/8" Id | eBay
High Pressure Power Washer Spray Gun Wand Lance Nozzle Clean Kit For Car Garden | eBay
Poly Bung Cap 2" Fine & Coarse Thread Combo w faucet for Plastic Drum Barrel | eBay
15 Pcs Stainless Steel Drive Hose Clamps Worm Clips 3/8"-1/2"(8-12 mm) | eBay
Thsi should get you started. Look on Craigs List for a poly barrel of the size you need....a 15 gallon size is about $10-15.
/ question about 3pt sprayers #5
My Spray Rig:
2011 Polaris Ranger Diesel
Ranger Sprayer - YouTube
It began as a:
John Deere 45 Gallon Tow Behind Sprayer - #LP20485.
That I picked up used locally for $400.
Over time, though, almost of all the original moving parts have been replaced but the basic idea can still be seen.
I can't imagine life out here without that Ranger & spray rig.
If you've got the money you can buy most anything but this is how we did it here in the wilds of this north Florida farm.
Use this as a rough idea of what you may or may not want and cobble together what works for you with whatever you can gather.
/ question about 3pt sprayers #6
I purchased one of the 25 gallon 12V no names from the local farm store about 10 years ago and other than having to clean up the switch one time it has never failed to work when I wanted. I have it mounted on an old Cub Cadet lawn tractor the wife uses for pulling her garden trailer and I hate admit it but half the time I don't clean or maintain it like I should, it keeps on working.
/ question about 3pt sprayers #8
Ed, before I bought my boom sprayer, I shopped all kinds. Elec, PTO, air, etc. Was told several times by different respectable sales people that unless you keep your tank in the garage when not in use, do not get a white plastic tank, as they degrade rapidly (not sure what that means) in the sunlight if stored outside. So I got a sprayer with a yellow tank. It is a heavier gauge of plastic.
If you choose to build your own, as another poster suggested, check Craigs List for sourcing your barrel. Or...I got one from my local car wash. I would assume Mike's have empty's all the time from the soap they use.
Also Roundup or glyphosate will corrode anything. So no matter what kind of pump you choose, be diligent in flushing it thoroughly after every use, tank too.
PS. I moved down here from Brownsburg. Had a house up by Eagle Creek reservoir.
Good luck in your search and decision.
sounds like a great option. do you have any pics of ur set up
Ur from brownsburg. Nice. We use to live by that huge church off of 231 north of town in that little subdivision. We built a home in the country 4 years ago. Inbetween darlington and Thorntown.
I remember a few years ago they had talked about doing some big project in brownsburg. Looks like they have it done. Kind of like a small carmel.
I have a back pack sprayer that i use to keep the weeds down with. It has some corrosion as i typically mix a bunch and then I just leave what's left in there. I have had it since we moved here. Every winter i flush, drain, and put in some rv antifreeze. Still works fine. I know with that i would have to empty and flush for sure if i were to go this route. If i can get one made for cheap then i may give it a go. I have a pole barn where i keep all that stuff. Tractor stays in the garage.
What part of Brownsburg are you around
/ question about 3pt sprayers #11
I bought 1 of these from TSC 12v electric powered.
Fimco 4 gal. 4-Nozzle 3 Point Hitch Sprayer, 532941 at Tractor Supply Co.
Only use in early spring to kill dandylions and broad leaf weeds in lawn.
Winterize by getting RV antifreeze into pump (-50 degree) around $4/gal.
I have this same sprayer. The 12 volt pump that comes with it has been nothing but trouble. I finally replaced it this year with the TSC version of the same pump. Hopefully that will hold up better. If not TSC offers a replacement warranty on theirs so I will take advantage of that.
I do put RV antifreeze in it for the winter. I think the chemicals just gum it up. And I do clean it after every use.
I believe the Fimco is suppose to be a better quality brand right? I was looking at some from northern tool which some brought up pump problems as well. Others speak highly but for the most part the reviews are solid. I may try to build one b/c its only going to be used for driveaway.
/ question about 3pt sprayers #13
Fimco will be fine for what you are doing.
I have the Deere 45 gal in the back of the gator for fertilizer spraying.
[side triv - was born in kokomo]
/ question about 3pt sprayers #14
Great idea.
I bought a pull behind from Northern Tool before I owned a tractor so I could pull it with the little lawn tractor. In hind sight, building one with a few bits and pieces would haver been a lot cheaper and just as effective. No way I would invest $400 in one.
My buddy gave me a 30 gal plastic barrel from a car wash. I doubt it would deteriorate very quickly, but if it did, it would be easy and cheap to replace.
One last thought. If you have a set of pallet forks you do not even need to connect the darn thing to the 3 PH. Cut down a pallet, strap the tank to the pallet and go for it. And no turning around to see how the thing is spraying.
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A62131)
UNUSED PAIR OF 76"...
(APPROX.100) 23"X95" EXPANDED METAL (A62130)
(APPROX.100)...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2021 Bobcat T770 Compact Track Loader (A61166)
2021 Bobcat T770...
2017 Ford F-250 Crew Cab Pickup Truck (A61568)
2017 Ford F-250...
UNUSED FUTURE QUICK ATTACH COUPLER (A62130)
UNUSED FUTURE...
