fuel gauge head scratcher
/ fuel gauge head scratcher #1
LouNY
Super Star Member
Greenwich, NY
Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Had an interesting issue with my 8050 the last couple of weeks.
Fuel gauge quit working properly, wouldn't read above a 1/4 of a tank.
Raking hay for a few days with her when the gauge guit, got the low fuel light so brought down a couple of cans of fuel.
Only poured about 6 gallons in when it was over full, spilled out the filler neck. Low fuel light cleared back to work.
Filled up at the farm pumps a few times (no meter) while doing some brush hogging and cleanup, different operators,
low fuel light a couple of times run over and fill it. Brought it home to do some driveway work knew she was full so ignored the
gauge and then the low fuel light all of a sudden started losing power got her turned sideways on the driveway the engine straightened ran good so started to work again and it happened again got her turned and running good and backed up the hill to the fuel tank (gravity fill no meter) filled her up didn't take long and back to work.
Started looking for the fuel sender, lifted the floor mat in the cab a nice little round hole to access the fuel sender, OK of course I can't reach the connector to disconnect it, called my dealer to check price and availability of the sender (almost $140) recommended dropping the tank (s) to replace. The 8050 has a 2 piece fuel tank a front section and then a main tank. Decided to pull the sender who knows maybe just a loose wiper on the resistor. Nope no simple sender here got a fancy sensor assembly, rod tube over 1/2" diameter with a float around it ( going to assume reed switches with a magnetic pull in) raised and lowered float gauge worked fine, hum called told dealer not to order sensor. Measured the fuel in tank only 5" should have been 3/4 s full, reading 1/4 full, filled a can and poured in 5 gallons reading about 1/2 whats going on now. Buttened the sensor back up in tank and fill jug again started pouring fuel in 4 gallons latter over filled at the filler neck????? checked gauge just over 1/2 went to the rear of the tractor and pulled a vent line of the tank fuel dropped in filler neck gauge reading almost 3/4 full.
The danged mud dabber wasps had plugged both of the fuel tank vents, on one they had even gotten down 6" in the hose from the tank to the vent gooseneck, the other just the gooseneck was plugged when they had finally sealed both vents the main tank wasn't being filled just a splash about a quarter in the main tank and filling the front section we were operating with maybe 8 gallons capacity on a 26 gallon tank but not having meters on the fuel dispensing tanks never realized we weren't filling the tank.
/ fuel gauge head scratcher #2
So Lou... your long national nightmare is over?
Well the fuel tank issue is taken care of for now anyways.
/ fuel gauge head scratcher #4
That is crazy! Hate how things like that will drive you nuts trying to get it fixed. Dang dirt daubers!
/ fuel gauge head scratcher #5
Several years ago I had problems with mud daubers. They would lay eggs & a couple dead spiders in the key slot on my riding mower. Then cap it off with some yellow sticky snot. I fought it all summer. Then - what the heck - I just left the key permanently installed in the slot.
I use a short chunk of sticky-backed foam tape on my new mower. Over the years I've lubed the heck out of the key slot on the tractor. They don't bother it.
/ fuel gauge head scratcher #6
I am glad you posted this Lou. Until you posted it I didn't realize that my 4720ch had even had two inter-tied tanks. If I'd have looked the tractor more closely I would have realized it, but it just never occurred to me to look until I saw your post. My problem is that my tractor acts like it has about a 6 gallon tank. My tractor will run out of fuel if there is any kind of side hill, and will only take 5 gallons to fill it. It is supposedly a 9.3 gallon capacity. My fuel gauge is so extremely erratic that I ignore it. I replaced the sending unit some time ago (under warranty) and it didn't help.
I am suspecting I might have a plugged vent line in the right side tank after reading what you have gone through, but have no idea how to access it.
I looked at the parts diagram. It is really screwed up and incomplete in labeling parts. The service manual also doesn't explain very well about things around the fuel tank either.
Guess I will just have to crawl under the tractor (one of my least favorite things to do) and see what I can find. I know the vent line exits right above the 3 point top link. How did you unplug your line, Lou? Can I just blow it out with air? Unfortunately I just filled my tank so I probably should run it down a ways first if I have to tear anything apart
I could access the hoses where they came off of the fuel tank and my "vents" which are simply 180 degree bends of tubing just under the rear window.
I pulled the hoses and couldn't blow air through them with my compressor and blow gun, after flexing the hose and finding the hard spots and really flexing them,
I could get the air to blow through and then I sprayed in carb cleaner and blew that thru then ran a piece of all thread (#10) through the 1/4" hose,
it took quite a bit of spraying and poking with a tie wrap to get through the vent tubes.
I'm going to add cheap fuel filters to the vents to try and keep the mud dabbers out.
I just looked at the parts breakdown for the 4720 it looks like your vent lines are coming off of the upper area on the inside of the fuel tanks,
they could be difficult to reach. I got lucky in that mine were easy to reach.
If you are lucky and the restriction is just at the end under the vent, removing the hose below it may help, on mine the mud dabbers had gotten 6" down in the hose so I had to remove the hoses to blow from the tank end towards the vent end to keep crap out of the tank.
Is your fill cap on the right tank or the left in the picture it looks like the right side, if so I would suspect either the other tank or after the tee.
As I could fill the portion with the cap as it vented while filling it.
/ fuel gauge head scratcher #9
Sure enough, The vent line was plugged solid. I looked in the down the end and it looked like there was an orange plug in it. I cut off the last two inches, that orange plug ended up being a paper like material packed in very tight. I wouldn't know a mud dabber if I saw one, but something sure plugged it up. The material went further up the line. I cut off as much as I could (about a foot) and it was still full of this stuff!
I looked at pulling the entire vent line, but that would be a very difficult task. No way I can get my hand up to disconnect them at the tanks and the tee is totally inaccessible. So I pinched off each vent line out of each side of the tank, one at a time, and blew air through them. They cleared ( I boiled a bit of fuel out of the fill spout in doing so).
Afterwards I was able to put about 4 gallons in the tank (I filled the tank yesterday, ran about a gallon out today by using the tractor, and boiled maybe a pint or quart at the most out when blowing the lines). So I obviously didn't fill both tanks yesterday.
Time will tell, but I am pretty sure that things will work better (I might be able to go more than 5 hours on a tank of gas and my fuel gauge might actually work)
Thanks again, Lou, for pointing bringing this subject up.
/ fuel gauge head scratcher #10
Pull up your rubber floor mat. You may be pleasantly surprised at what you'll find......access plates.
/ fuel gauge head scratcher #11
The fuel tank vent tube connects to the upper section of my fill pipe. It's a closed system that the mud daubers can't get to. It's the vent for the rear transmission that has the small filter on its end. I found, over the years, fuel gauges are not sophisticated enough to be really too accurate. At least, on tractors & riding mowers. Over the road vehicles - different story.
My answer to this - simply fill the fuel tank after each and every use. I've never run any of my equipment long enough, at one time, to use much over half a tank.
Glad it worked out for you,
it's amazing how much work a little insect can cause and
how nice it is to get a full tank of fuel in.
/ fuel gauge head scratcher #13
I made that discovery shortly after purchasing the tractor, and I did pull my mat and removed the access panels yesterday. Access was still much better from under the tractor and if I had the hands the size of a 5 year-old, I could have easily removed the lines. Fortunately I could get to the lines with some needle nosed vice grips to pinch them off so I could blow them out individually.
/ fuel gauge head scratcher #14
My situation is a bit different than yours. I quite often use my tractor for long stretches of time continuously (it takes over 10 hrs to mow my west 19 acres). I have ran out of fuel in the last year or so more than once, and it is usually where I have to walk the furthermost to get fuel. The fuel gauge worked fine for quite a while after I got the tractor, but seems to have a random position generator lately, which doesn't help. Both problems appeared around the same time. Hopefully both of those situations are rectified.
/ fuel gauge head scratcher #15
As a preventative measure, I did follow Lou's lead and ordered a $5 small engine fuel filter to put on that vent line and would advise others to do the same
2021 Ram 5500 4x4 Crew Cab Service Truck (A61573)
2021 Ram 5500 4x4...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Sakai SW354 (A60462)
2021 Ford F-150 4x4 Pickup Truck (A61573)
2021 Ford F-150...
LERN REMCOR ICE DISPENSER, MICROWAVE (A64276)
LERN REMCOR ICE...
2023 Isuzu NRR Crew Cab 20ft Dovetail Flatbed Truck (A61573)
2023 Isuzu NRR...
