Furnace making funny noise
/ Furnace making funny noise #1
check
Elite Member
Dorset (cottage country) and Toronto, Ontario, Can
2009 Kubota BX25
Hi, Folks, I need to identify a noise that my high efficiency propane furnace is making, and I am hoping some of you have heard this before. The supposedly experienced service guy could not tell what it was, and so he just "guessed" it was the ($800!) fan motor.
It is a Payne Model PG96VAT48080 furnace, installed in August of 2013, and has worked fine up until now. But just recently, every once in a while there would be this strange kind of buzzing/honing sound when the fan was going full blast (e.g, on AC).
Here is a video link:
IMG 1884 - YouTube
It is very intermittent, and seems to only come on when the fan is on high.
Any ideas, my fellow TBNers?
James
/ Furnace making funny noise #2
No tube here, but from your description, maybe a fan bearing. Maybe an obstruction that gets drawn in with the higher airflow?
My refrig/freezer sounds weird sometimes. Finally figured out it wasn't defrosting properly and frost buildup would encroach on the fan blades at times.
/ Furnace making funny noise #3
you're getting ripped big time if he wants $800 for a fan motor, the video has no audio, but it has to be a worn fan motor, that's the only thing that moves!..
/ Furnace making funny noise #4
Most of Those newer units use a dc inverter fan, variables speed. There spendy but not $800. Get part number and hit ebay. I replaced mine years ago....was less than $200 and took 10 minutes.
The compressor fan on my monagram built in fridge was failing. GE repair wanted nearly a grand to repair it. I got motor on ebay, direct OEM, for $90, took about an hour to install. Never did one before. Fridge works like brand new. No noise.
/ Furnace making funny noise #5
First need to determine correct terminolgy from the OP. There is a difference between a fan motor for exhuast and a blower motor. For $800 I'm guessing it's the blower motor (added the fact that the exhuast fan motor really shouldn't have an affect on running the AC, but the blower motor would).
I installed my 80% variable speed gas furnace with a heat pump in my attic around 2004. Last year my blower motor went out. One of my few work perks is I buy directly from the manufacturer. As noted, I believe what the OP is refering to is the blower motor. My cost on that variable speed constant airflow ECM motor was WELL over 50% of the cost of what the OP was quoted (and my luck, it was past the 10 year parts warranty). If he gets it installed for $800, he wouldn't get ripped off IMO. As far as moving parts, need to look at the blower housing assembly as well, which includes the blower wheel).
Customers expectations are that if the unit is making a noise and it's diagnoised at being the blower motor, if the motor is replaced and the furnace is still making the same noise, the contractor should make it right and fix the "real" issue at no charge.
That said, if the gas furnace was installed in 2013 and it was registered, it should have a 10 year parts warranty, which means ANY part would be free, but the OP would still have to pay the labor to change it out. Since it was installed in 2013, not certain why it wouldn't have a 10 year parts warranty?
Carrier came out with on of the first variable speed ECM motors in the 1990's. Cost back then for the motor was about what I paid for mine in 2019 (20 years later). When I first saw the cost of the motor (not what the contractor pays for it) I remember joking to a guy back then that "dang, the cost of this new motor costs only a little less than a complete new gas furnace."
Due to FER regulations, PSC driven gas furnaces are no longer being made (those are the "cheap" permanent split capacitor motors that you could buy all day long for under $120 at supply houses). Every furnace now being produced (including electric mobile home "furnaces") now have at least the much higher priced constant torque ECM motor (AKA the X-13 back in the day LOL).
FER Standards Require Electronically Commutated Motors | 218-1-29 | ACHRNEWS
On a sidenote, we can thank California for the higher priced blower motors. Still more stuff coming down the pipe in the next couple of years due to that wonderful state.
Thanks, Sigarms, I am pretty sure it is the blower motor that the HVAC guys wanted to replace. And yes, it normally costs about $817, but is covered (parts only) under the 10-year warranty. However, the labour is some $500 to install it. I also sent a note to Payne with the video in case their people know what the cause is. Frankly, I am surprised that no one recognizes this sound - it is very distinctive. And it is VERY intermittent. One theory was that the cause was a hi-test, high efficiency, HEPA furnace filter, which apparently restricts the airflow quite a bit, making the
blower work extra hard to get the necessary volume of air flow. So I put in a cheap filter, and things were fine for a while. Just recently, however, it happened again while the AC was on and the blower was on high (which the furnace itself determines), and this time it did not stop when I put a new (cheap) filter in.
/ Furnace making funny noise #7
Honestly, I didn't watch the video. Ok I just did now LMAO. Sounds like the motor, but was the blower wheel and shaft looked at as well?
$800 for a variable speed constant air flow ECM motor is pretty much the norm.
I hate to say this, but $500 isn't too bad of a price for labor for that kind of motor. A good HVAC contractor/company will give you one year labor on the warranty part IMO. Meaning if you spend $500, you know it's fixed for at least a year with no more money coming out of your pocket if the service work performed doesn't eliminate the original issue). Good contractors will also offer you a service agreement, and a good business practice is to offer discounts on any labor work because you have a service agreement with them. That said, at $80 for a service call, 3 quotes is still costing you $240, but you could call different companies to see what they offer and what they charge for service work.
If a guy is going to charge you $500 for labor to replace the motor, he should of looked at everything to ensure that this is the actual issue and it's not a question of what the best odds are as when I watched the video. I'm behind a computer, I didn't take the time to come to your house. Better service techs will video what they take appart and show the homeowner the issue. Did you take the video or the did the service guy? If you took the video, I'd drop the guy that came out because you're doing more work than him. Ultimately, good companies who do good work and communicate clearly with their customers are not the cheapest.
However, considering the motor type and filter "change up" you mentioned, any decent service tech should be noting the static pressure along with CFM's (and give you a copy for your records as well). Your furnace installation instructions has a blower table along with allowable static pressure along with allowable CFM's (reason why proper ductwork sizing is important if a new system is being installed).
By collecting this data (SP and CFM's), it will let you know exactly how much "strain" a certain type of filter is having on the system for certain. This is why this kind of data is important with that kind of motor IMO. Without knowing the size of the ductwork, it's possible even a standard 1" poly filter could be running higher than normal static pressure. 7 years for a blower motor isn't unheard of, but I'd want to make certain the ductwork system isn't straining it. By doing this basic work of measuring SP and airflow, it's not a theory of what could be wrong, it will tell you for a fact either way of what is the issue of premature failure.
The "magic" number on a good static pressure is a .50 with around 340-400 CFM's per ton (I would guess anything over a .85-.90 will cause premature failure on your type of motor). The reason why you measure both SP and CFM is because some guys will lower the fan speed to decrease the SP. Only problem is if you aren't hitting you're CFM's by lowering the fan speed, you can kill the compressor (checking actual CFM's the system is producing will verify this). Guys always want to jump to gauges first for readings on AC issues, but without verifying air flow and SP first, your refrigerant readings could be off without even knowing the real reason. Old instructor always use to say know your A,B,C's (airflow before charge).
FYI, Payne and Carrier are made at the same plants. Same company, different marketing.
Ironically enough, the cheaper PSC blower motors were more immune to higher static pressure issues than the much more higher priced variable speed constant air flow ECM motors (I've seen 1.2 SP have a constant negative affect on PSC motors as well, which would kill your type motor rather quickly). So what's the US government do? Make it illegal for manufacturers to use PSC motors now in their new furnaces.
/ Furnace making funny noise #8
So what's the US government do? Make it illegal for manufacturers to use PSC motors now in their new furnaces. The reality is at the end of the day, I'm not certain if we're really saving money.
You can always count on the Government to mandate what's best for the peasants !
/ Furnace making funny noise #9
Just be glad you're out.
Part of what's coming down the pike by our federal government is static pressure and how it correlates to AHRI ratings.
Keep in mind, this won't affect service or retrofit equipment, but it will affect new installs with ductwork on new homes that are inspected.
/ Furnace making funny noise #11
My neighbor has the Trane unit installed in 2009 with a bad fan motor and its out of warranty - $1500 to replace the blower motor/fan. A complete new unit is another $2K so he may go that direction.
/ Furnace making funny noise #12
IMG 1884 - YouTube
James
You have 2 shots, the distribution fan motor and the combustion air blower. One of them has failing bearings you can replace both yourself for a lot less than 800 clams. Better determine which it is before it gets cold and replace it. HF furnaces use a sealed combustion chamber that relies on a combustion air blower to provide air for the burn process. That will be on the front under the front panel. The distrubution air blower is underneath on the bottom.
/ Furnace making funny noise #13
I need to be in the furnace repair business. I can buy both fans, all the component parts and install it for less than 600 clams and all it takes is some time, a few wrenches and a screwdriver. It ain't rocket science.
/ Furnace making funny noise #14
Our Plus 90 condensing furnace is only for backup. I heat with shelled corn and wood pellets. While propane is cheaper right now, I still prefer the heat and ambiance of an a fire that you can see. besides, I like to toast my feet in front of the fire.
/ Furnace making funny noise #16
I think that many if not most of us outside of the sun belt can identify with that. A good fire of any type is also more steady heat.
/ Furnace making funny noise #17
You should. Being you're in Michigan, to make a run of it you probably should know a thing or two about hydronics, perhaps oil along with maybe coal? Let's not forget about mini splits. Then get a van, make sure you have insurance, most likely need at least 5k-10K in decent tools, have the proper licences, and just wait for that phone to ring because you can offer everything at the lowest price and everyone knows it.
I'm sorry, I understand that people think that HVAC is where the money is at because of pricing, but the reality is if you understand your overhead and what it actually costs to run a business, added the fact that you're the one driving to the customer instead of the customer coming to you, people that know their chit that want to stay in business for the long haul are not the cheapest price in town.
THEN you get the interesting customers who wonder why you charge $80-$100 for a service call to diagnois the issue because you're the expert :laughing:
You can always get a weekend warrior that works full time and does it on the side, but when you need something done, see how reliable he is getting out to your place. Roll of the dice at best.
I get it. Everyone here can do everything themselves. That's great. The reality is those that can do it all themselves are in the minority, not the majority.
By the way, there is no way in hades you can buy a Payne variable speed constant fan blower motor (under warranty) along with a combustion fan motor (generally sold with the complete housing assembley) for less than $600 alone (less the labor). With that blower motor, you also better have the wiring schematic.
You might go cheaper going aftermarket parts if you could find something that would work, but with 3 years left on the factory warranty, if those aftermarket parts failed within that time, you as the contractor are eating it.
/ Furnace making funny noise #18
How you gonna make a living installing these items for cost ? Mileage, tools, insurance, license, bond, etc,.
Then, most will warranty the part /labor for one year.
How do you stay in business ?
Asking for a friend
/ Furnace making funny noise #19
My good friend over in Stockton Springs (west of Bah Harbor a tad), has been cutting and splitting wood all summer for this winter. I think he has about 6 cords stacked in his basement already.
Gets pretty blustery up your way. Gets blustery down this way too.
Wood pellets are a bit less down here than up your way and we have shelled corn too. You don't. What I'd like to have is a stoker stove but rice coal is hard to come by here.
I'm not overly fond of condensing furnaces in general because of their complexity and high repair costs, especially if you cannot do the repairs yourself, but I will say they are efficient when it comes to fuel usage and out here there is no NG, only propane.
/ Furnace making funny noise #20
Asking for a friend
I'm not but that won't stop me from doing my repairs. Other than the brain box, most of it is R&R. Last year my distribution blower took a dump, mid winter. A new one from Grainger was 400 bucks and the OEM one was 600. Turned out to be the start capacitor for 10 bucks. When I took it out I went through it and greased all the bearings and blew out all the accumulated junk in the motor (yes, even with a furnace filter, some junk still gets by). Of course I wasn't cold. The parlor stove upstairs kept everything toasty.
One of the big ticket items on any condensing furnace is the combustion air (inducer) blower. When it goes, expect to lay out some serious jack but like all furnace parts, not hard to replace yourself. Mine is getting a little noisy, should start thinking about buying one for eventual replacement.
