What have you done to your Branson today?
   / What have you done to your Branson today? #641
Thanks for sharing. I am in the process of setting up a service pallet that I can use remotely when needed. I still have some thinking to do before I start cutting steel. I am going to use a plastic pallet for the platform but I might need a little bigger one to fit everything nicely. I still need a container for grease gun and oils but pretty much have everything else.
I am going to frame behind the compressor with 2" box tubing and mount a retractable hose reel to that. Probably will use 1" for the rest of what I am framing but going trying to keep it light as possible. Here is a picture of what I am thinking so any ideas would be appreciated.
Nice setup K5. One thing that might be handy is an inverter for those times that you might not want to fire up the generator/compressor for AC power. The nice thing about the inverters are that they take up very little space, can run off the tractor's electrical system and would be located really close to the battery compartment. A good quality true sine wave inverter with cables that can push 12-14 amps is around $200.
   / What have you done to your Branson today? #642
Thanks Bob, I have been working on the project some. Heat and MS do not get along! I get to shop around 4am and can go to about 7 or so before my body crashes. Weekends only.
I have everything welded and painted so next weekend will be final assembly. I look forward to cooler weather so maybe I can get some other projects done.
   / What have you done to your Branson today? #643
Looking K5. BTW, how do you like your Kioti?
I'm looking at getting a used tractor so I don't have to jockey so many implements back and forth... (haven't told the wife yet, shhhh)
   / What have you done to your Branson today? #644
The Kioti has been a good little tractor. Dealers here are not that great and parts are expensive when available. I have managed to fix things with Kubota parts and other aftermarket stuff with a little modification. But still a very capable machine and is in better shape than it looks. :laughing:
   / What have you done to your Branson today? #645
I had my hydraulic toplink cylinder off a while back when using my post hole auger. When I put it back on I wasn't paying attention and installed the cylinder with it's fittings and hoses on the same side as the rear remote quick disconnects. It worked fine but I failed to notice that installing it that way allowed the forward most hose to chaff against the quick disconnect under certain conditions. This weekend that hose sprung a leak due to that chaffing and I had to scramble to get a replacement. First thing learned: Always put the top link on with hose fittings on the opposite side of the quick disconnects.
It sprung a leak at some point on Saturday while I was mowing a 20 acre chunk of land for a guy who lives about 15 miles away from my home. I was almost done mowing when I noticed it. I left the tractor parked in the field as I had the new hose made. I didn't know how long it had been leaking or much hydraulic fluid had leaked out. I looked at the sight glass and it looked like it was low. So this morning I had brought over a gallon of tractor fluid to put in it when I put on the new hose. The access to the fill port is easier to access with the three point lifted. so I raised the bush hog all the way up. I put the gallon in and didn't see any change on the sight glass. Then I remembered the thread on this forum about the sight glass appearing to be empty when it is really over full. I looked closely and realized the tractor was parked slightly uphill. So I realized that it might indeed be over-full. I was unsure what would happen if you operated the unit with too much hydraulic fluid. But pulling the drain plug drain to drain some of the fluid out in the middle of a field sounded kind of risky. And what happens if it was not really over full but in fact really really low? Running too low sounds riskier that running over full. Everything seemed to be working fine when I shut the tractor down, ,, but it might indeed be low. Is running it over-full a major problem?? What to do?? To check things out properly I felt that I needed to trailer the tractor back to my shop. It was 15 miles to home most of which is down a nasty bumpy gravel road at 10 mph. After much contemplation I reluctantly decided to just try to finish the little bit of mowing I had left to do with the tractor as is.
I started up the tractor and went to lower the three point to mow, but it wouldn't lower!
Now I was unsure if it was overfilled or if it was empty , or if I had broke something. I nervously loaded up the tractor and took it home (took close to an hour). On the way home I realized I could drain the fluid back out by disconnecting the hose at the top link cylinder and just operating the lever to take out exactly one gallon, and I could have done that in the field. But I was almost home when I thought of that. At home I managed to pump that gallon back out using that method. After which, the top of fluid showed up in the sight glass, and low and behold, everything worked again just fine! But my lack of attention sure cost me a lot of time!
So the other things I learned: 1) The sight glass for the hydraulics is easy to miss-read. 2) Be sure the tractor is setting level when you check the fluid, and 3) If your three point goes up but not down, you probably have too much fluid in the system. With hind sight, I could have finished mowing with the leaky hose as it only leaked when I pushed the rear remote lever, and I don't really need to adjust the top link for mowing. Funny how you get smart too late.
Hopefully someone else can learn from my misadventures.
   / What have you done to your Branson today? #646
My 8050 holds 15 gallons of hydraulic fluid,
I routinely run 2-3 gallons over full.
I have a lot of steep hills that I work on.
On the farm we usually run almost 5 gallons over full because of the hills.
Those are larger systems.
I point mine down hill to see how much fluid it has in it.
As to why your 3 point wouldn't go down I have no idea,
mine is electronically controlled and when started up it has to be lifted slightly before it will function normally.
When it is fully raised I have to lower and raise the control before it behaves normally.
   / What have you done to your Branson today? #647
Well got the service pallet complete. Overall I am happy with the way it came out.
I had to offset one post to clear the handle on the compressor.
The little wood box I found holds fluids, grease gun and the radiator genie.
Here it is filling the Branson.
Thanks everyone for you suggestions. Just ran out of room to get everything on there. But this will cover routine maintenance.
   / What have you done to your Branson today? #648
Looks great K5. I like the swiveling hose reel and the layout looks well thought-out. The pull cord, tool box, fuel tank all face the right direction. I'd like to see a peak inside the toolbox. Also is that a tiller or a flail mower and is that a swing arm?
   / What have you done to your Branson today? #649
That came out real nice there K5.
Looks like that is an offset flail mower?
   / What have you done to your Branson today? #650
Thanks Guys,
Yes that is a ditch bank flail mower. I really like it even though it is a cheaper Chinese mower.
I will get a picture of what is inside the box when I finish gathering everything together. It just has an air chuck, blower and impact in it now.
43055 (A55851)
43055 (A55851)
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
LOT: (3) Adjustable Steel Racking Sections, 9' W x 24" D x 56" H (CONTENTS NOT INCLUDED - DELAYED (A59076)
LOT: (3)...
More info coming soon! (A55787)
More info coming...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
