Gravely's
/ Gravely's #1
Sonny580
Central Illinois
several kinds and sizes
just got these 2 and dont know a thing bout Gravely's! lolo! --- always wanted one---guess they only come in pairs! I cant find serial number on one and the other says LI and serial# is 2793 on it. Neither one run, motors are not stuck so maybe I can get them running. one needs a gas tank and the other one needs cleaned---nasty old gas in it. From what I was told the ran when parked! LOL!! --- actually they were just sitting in a shed for many years so a lot of cleaning will be needed to start with after I learn a bit about Gravely's!
I have more pix of them showing the sides of the motors.
/ Gravely's #2
Reminds me of buying an old radio when I was a kid "It was running good last time I heard it".
Good, solid old machines - hope they work out for you. :drink:
/ Gravely's #3
Good luck. Bought a 5665 (12 hp) in 2001. Couldn't use it until I got some steering brakes. Luckily, the ex Gravely dealer in town had some.
Maybe on the smaller ones, you'll be able to steer them without the steering brakes.
Ralph
/ Gravely's
I am sure they are a bear to run!---- they are heavier than then they look! gotta be over 250 pounds with the mower on them. --- and I thought a Troy-Built Horse was bad! lol!
/ Gravely's #5
How big of an electric drill do you have,, or can borrow? (not an impact tool, a true drill)
Get a socket that fits the big nut on the crank pulley, and a socket/drill chuck adapter,,
Take the plug out, spin the engine a while with the drill/socket,,soon the magneto will start putting out spark.
(cranking is easier than taking the magneto apart and cleaning it)
When you got a good spark, put the plug back in, start spinning, and dribble a little gas in the carb,,
if it tries to start, then it is time to dig into the carb,, and it will run just fine,,, :thumbsup:
/ Gravely's #6
I am sure they are a bear to run!---- they are heavier than then they look! gotta be over 250 pounds with the mower on them. --- lol!
The weight gotta be more like 600-700 pounds,,
I got a 2 blade , 40 inch mower that weighs 250 pounds by itself,,
/ Gravely's
I have a couple big old heavy slow 1/2" drills.
/ Gravely's #8
One thing I ran into on the 5665 is that you could not set the points at 0.020. Otherwise, they never close. Have to set at about 0.016.
Ralph
/ Gravely's
One dont have spark, mag clicks but nuttin on the tester, the other one dont even click. --- I despise mags on motors! I always end up having to convert them to battery coils. Next up will be to try to file the points in the mower one and try to get spark---- IF that dont do it ---- well battery coil time!
/ Gravely's #10
My brother rebuilds/repairs/recharges mags for these old Gravelys. PM me if you want his contact info.
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
