Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #14,961
Hit the "Go Advanced" button before typing in your response. That works for me.
Thanks reb. Just on iPad at moment. But I see that option on the iPhone. I値l try it out next when I have that.
   / Tractors and wood! Show your pics #14,962
Ok. I guess it does it on iPads as well. So here I am, typing a message just to see if go advanced works in fixing the typing issue.
I know old path will be jealous of that mahindra tractor but I cant stop sharing photos with you all just because I might cause one follow to spiral into a darkened pool of depression over someone else's fine tractor.
   / Tractors and wood! Show your pics #14,963
   / Tractors and wood! Show your pics #14,964
The final and most dangerous tree is down
   / Tractors and wood! Show your pics #14,965
That one looks like it has a log or two in it. The other day you mentioned generating a lot of bio-mass in this project. What do you do with that ? I have a hard time breaking even on bio-mass here so most of it stays where it falls. I only move what I have to.
gg
   / Tractors and wood! Show your pics #14,966
Cool, sounds like you have been having fun...BUT.... you have to explain that box with the stand in the picture.
I'll only be 95 in 2050.. And probably be pushing up daises.. I'm not fancy enough to push up geraniums! ;)
The box is off the floor so tractor forks can get under it, so in two weeks I'll set the AC on it, then cover it, then ratchet strap box top down and see you next June, summer is over, yee haa!!!!
   / Tractors and wood! Show your pics #14,967
That would be 13.3 bd. ft..
"IF" I had it, and it was decent, I'd probably say 20 bucks...
SR
My son says he sells his cedar at that same price, $1.50/BF=$20.00-ish for a 4x4x10'. He also said if a 4x4x10' white oak sells for $14.00, that $1.05/BF.... So I dont think I wasn't to far off on $.90 BF for red oak or $12.00....
   / Tractors and wood! Show your pics #14,968
The grade makes a lot of difference. Here prime white oak is going for $1.30 a foot in the log and thatç—´ from a mill that doesn稚 even saw it so theyæ±*e selling it to someone else for more money. I壇 guess theyæ±*e making 20 percent for loading and trucking it. But I知 guessing theyæ±*e not sawing barrel grade oak into post and the next grade down is worth like half. As long as theyæ±*e solid without major defects I壇 say $14 is a good price. Btw a board foot is a square foot an inch thick. For most calculations you値l be using 144 cubic inches of wood per board feet. If you were doing a even number like 6 or 12 inches wide maybe you wouldn稚 bother converting to inches. A 12 wide 1 think board 8 long would be 8 BF no calculating necessary. 4x4x120 ( can稚 mix feet and inches for calculating) = 1920 divided by 144 = 13.3 feet.
Thanks for the BF lesson, I always have to ask my son. 1"x12"x12' is 12 BF, thats all I can remember.....
   / Tractors and wood! Show your pics #14,969
Take the AC out of the window, set it on the base, set the cover over it.
I just set mine on an overturned 5 gallon bucket though.
Thats exacly right, you must of seen the instructions written on the box.
   / Tractors and wood! Show your pics #14,970
Hey OP, you were asking about progress on my Deer Sniper Tower... finally got out there again and put stairs up to the upper deck.
I was going to mention it this weekend so you beat me to it. Looks like a split roof design going on, half flat, other half has a pitch so the snow will slide off next month and your wife is inside ordering pizza.... :thumbsup:
Payment Terms (MUST READ) (A50775)
Payment Terms...
TRUCKING INFO (A50775)
1004 (A51572)
1004 (A51572)
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
