New House Build in WV
   / New House Build in WV #1
TnWV
Liberty,WV - Putnam Co.
2003 Zetor 4341 w/FEL, 1970 MF 150, 2012 JD X530
Hello All,
I have been planning a house build for a number of years and it is finally underway. We got a late start due to COVID-19, but the poured wall foundation was poured in late June. I am building the house myself, subbing out the pieces that I cannot/don't want to do. So far it has been mostly myself, my wife, my father in law, and one good friend who helps out when he is not traveling for work, so progress can be slow at times. I have been trying to get this thread started for a while, but work has been continuous until well after dark most days.
So far we have managed to get the basement water proofed, drain lines in, most of the gravel backfill done, concrete floor poured in the basement and we are now working on framing walls. Still have a few interior walls and a couple of garage walls to frame. Not all interior doors are completely framed in yet either. We have found it much easier to lift walls by ourselves if the headers are not put in until after the wall is in place. Trusses are do onsite in about 1.5-2 weeks, so hope to be ready for them as soon as they arrive. I will have some hired help to set the trusses and will also hire a crane to lift them in place. Currently talking to a contractor about getting them to sheath and shingle the roof, as those two tasks would take me forever to complete, so hoping that works out.
The house is one story over a full basement with attached garage. Front and rear porches will span the full length of the house, with the front being concrete and the back being treated frame with composite decking. We put PEX in the basement concrete floor for radiant heat.
Main floor is about 2200 square feet. Looked small on paper, but it definitely is not small now that it is going up! At this point, the only portions hired out have been the excavation, the poured walls, and the basement concrete floor.
House build threads are my favorite and I have followed everyone posted on this site for the last 10 years or more. I have to say I have learned a ton from those that have been willing to share their experiences and following those threads is not doubt helping along the way on this build.
I purchased a set of forks for my tractor prior to starting and they have been a life saver to move material around, especially the 34" I-joists and 3/4 subfloor sheathing. Its has been nice to be able to scoop up a load of studs and place them on the sub floor, keeps us from wearing out just getting lumber to where we need it.
A bad storm moved through on Tuesday evening causing a lot of damage around my property, including putting a 6" tree limb through the roof, and bedroom wall of the mobile home we are currently living in, on site. Dropped lots of trees, tore roofing panels off my big building and took down a large portion of my goat fence with another huge tree. Repairs and cleanup have caused no build progress for the last couple of days, but will be back to building walls tomorrow evening and over the weekend. Once walls are done, the next major step is getting the back porch framed. I hope to get the posts marked and dug this weekend, but looks like Saturday may be a washout, weather wise. If so, we will take that time to go get our windows and doors ordered.
I will add some progress pictures and try to put the blueprints up so you all can see what we will end up with. For some reason, the TBN website is not allowing me to add pictures through the manage attachments function, so I will have to work on that later. Below are the only two pictures that I can get to upload at the moment, maybe I will have better luck from the tapatalk app then my computer.
Here’s a picture of the forms up, right after the pour.
Some shots of the framing. We are much further along, just haven’t taken updated pictures. I’ll try to get some tonight.
   / New House Build in WV #3
Looks good, keep us posted. I also have poured walls in my basement. I did my house about 15 years ago. My worst problem after build was the pour on the front porch. They did not back the fill under the porch. It cracked after 4 years and dropped about 4 inches. I had to cut it out and do over. This time, packed the fill and poured with steel and thicker. I also wish that I had dropped my back deck about 2 inches more and left more slope for the water to run off. The cracks between the boards filled with dirt, leaves and trash and water stood on it and ran into the basement. Never overlook waterproofing every thing. If water can get into a basement, it will.
   / New House Build in WV #4
Thanks for starting this thread Tony. Looking forward to following your progress!!!!
It’s going to be fun watching it all come together. Progress is likely to be slow, but we will get there one step at a time!
How did they pour your porch? It would cost thousands in rock to fill mine. I put 1/4 inch angle along the front and planned to get metal panels designed to pour concrete on to span the porch. The panels are a fraction of the cost of rock fill. This is common around here and I have not heard of problems, hoping it’s not a risky option.
The biggest mistake I’ve made is not running the basement all the way under the front porch. I simply did not anticipate the hole being so large, or it would have been a no brainer to gain that space for very little extra cost, not that we need the space.
Speaking of rock fill and drains, I have already used 125 tios of river rock in my drains. At $800 per 25 ton load, gravel is costing me a fortune. I have also used 50 tons of 57 so far. I’m expecting to be at 300 tons of gravel before I’m done......
Here is a few shots of the drainage work.
   / New House Build in WV #8
Looks good! That was as heck of a storm the other night. Im over in Hurricane and while we didn't lose any complete trees this time, it certainly "trimmed" a few!
Looks forward to reading your thread neighbor!
Yeah, your not far away at all, we spend a lot of time in Teays Valley and Hurricane.
It was a heck of a storm, , that’s for sure. Worst we have seen since the derecho in 2012. Lots of damage in a 4-5 mile stretch over here. One tree landed on my current home putting a 6” hole through the wall into our master bedroom and another through the roof. Also pealed 3 sheets of metal off my biggest building, and dropped many other trees in our hay fields. The repairs and cleanup has slowed the build this week.
We were fortunate no one, or any of our animals, were hurt. If the tree went 2 feet to the right, our house would have had major damage.
Got out of work a little late and it rained once I was home. Still managed to build and stand up 2 more interior walls before dark, so not a total loss.
   / New House Build in WV #10
Really impressed with your foundation and framing. I'm curious why you didn't run your sheathing all the way down to your rim joists?
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55787)
2023 Caterpillar...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A54757)
UNUSED RAYTREE...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
2006 Caterpillar 315C L Hydraulic Excavator (A55787)
2006 Caterpillar...
UNUSED SDLANCH SDLJC HIGH-END MOBILE JAW CRUSHER (A54756)
UNUSED SDLANCH...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
