quick hitch cat 1 for cat 2 tractor
   / quick hitch cat 1 for cat 2 tractor #11
I just checked a Cat 1 Land Pride QH15 quick hitch. The bottom openings for the 3 pt lift arms are 1-7/8 inch wide.
The lift arms may be designed to have replaceable balls, if so get cat 1 balls for lift arms.
the t4020 has replaceable balls but the workmaster 55 doesn't have them.
Thank you, I will run by the kubota place down the road and take a look, I think that will work. I had a harbor freight one several years ago that the bolts for the top hook got in the way. the Imatch is a welded hook so no issues there. do the land pride bolts rub on anything or is the hook stuck further to the rear?
I want to stay with the quick hitch vs pats as I've already modified most everything to fit that didn't come that way from the factory.
   / quick hitch cat 1 for cat 2 tractor #14
I had the same problem with the upper bolts and clearance issues on a HF hitch. The top hook on the Land Pride sticks out further and so far no issues. I have 2 implements that need some work to be quick hitch compatable.
Thanks for that, I just wanted to make sure before I spent the money on it that it will work.
   / quick hitch cat 1 for cat 2 tractor #16
Is there a quick hitch that will fit cat 1 implements that will fit on a cat 2 tractor. My Imatch is only 1-3/8 wide where the lift arms fit and my new holland tractors have cat 2 lift arms that have 1-3/4 wide lift bushings. I don't want a cat 2 width quick hitch as the cat 1 quick hitch will fit all of the cat 1-2 implements as well as the cat 1 only stuff. I have looked around but haven't found anything.
LeeAgra Farmhand quick hitch-cat 2 on tractor side, cat 1 on hitch side. Got on wait list late last year, got mine in easels spring. Works great-built like a brick ****house.
Use mine on an LS XR4155HC
   / quick hitch cat 1 for cat 2 tractor #17
What GSVette said. I have one and LOVE it! And it's Cat 1 & 2 on the tractor side! And it has 2 5/16-3/8" grab hooks welded on each side! And it has 3-2" Reese hitch sockets welded on it, under the top link and below the lower links!
   / quick hitch cat 1 for cat 2 tractor #18
Forgot to mention those additional features-just finished using the hitch feature to move a trailer into the shop for rewriting.
Farmhand was well worth the wait.
Thanks, I like the looks of the farm hand however when I go to their website it looks like they might have discontinued it, lots of missing links and can't see a price anywhere.
   / quick hitch cat 1 for cat 2 tractor #20
Give them a call and see if they have indeed discontinued it or if they'll build you one...and post back here with their answer please!
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56436)
Koyker Loader...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2015 International Bucket Truck (A55973)
2015 International...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
