Oil & Fuel Branson Fuel Filter
/ Branson Fuel Filter #1
Nickak8
Member
Marcellus, MI
1956 Massey Ferguson TO35 Branson 3515R
See image. Have 50hrs on my 3515R and it appears there are some small black chunks in the fuel filter bowl. More importantly it looks like there is a large red o-ring in the bottom. No running issues. I was going to remove and take apart to see if I could put o-ring back, then I realized it looks like a sealed unit.
What are your thoughts on best course of action?
/ Branson Fuel Filter #2
You have to replace the whole unit. Red o ring is a water indicator.
Ok, so basically there is nothing wrong with it and it’s indicating no water? That’s good news.
/ Branson Fuel Filter #4
That's right.
If you had indeed water, you would just open the drain on the bottom of the filter, drain all the water out plus a little bit of diesel as good measure and you would be good to go.
Awesome, thanks guys. Appreciate the quick answers.
/ Branson Fuel Filter #6
IIRC, the red ring is a float. When you have water in the bowl the red ring floats on top of the water to indicate you have water. At least that's what my manual states. But my float is white. I don't think it matters. B.
2013 Dodge Challenger Sedan (A60352)
2013 Dodge...
LOT LOCATIONS (A59906)
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2020 Sellick S80 (A60462)
2020 Sellick S80...
