Toolbox for a 3515CH. Ideas?
/ Toolbox for a 3515CH. Ideas? #1
huntsman1024
Stevens Point, WI
Branson 3515 CH
Just wondering if anyone has figured out any place to mount a toolbox on a 15 series cab tractor? I just got a new 3515CH and I'd love a place to throw a few tools and some chain. Any ideas would be appreciated.
/ Toolbox for a 3515CH. Ideas? #2
I made a L-shaped bracket and mounted it where the step for the right side would mount.
For me it's no big deal as I don't ever mount the tractor from the right side, also didn't come with a step in the first place.
I don't know how well it would work for you. I've seen toolboxes mounted on the loader mounts as well.
This is mine but I don't know how well would work with a cab as I think the lid would hit the door glass.
/ Toolbox for a 3515CH. Ideas? #3
I thought about mounting one in the same spot ptsg. It would have to be lowered on the cab version but could work. Maybe one day I will get around to mounting a box.
Huntsman, please let us know what you figure out.
Is the tank on your 3515C mounted below the left step or behind the cab? Mine is behind the cab but the ones I looked at on the lot were under the step. If that's the way yours is, you might be able to mount a box behind the cab.
My tank is behind the cab. I had hoped to get it near the step, but that wasn't an option for me.
/ Toolbox for a 3515CH. Ideas? #5
I sometimes wrap a log chain around my front bumper, but it has fallen off on occasion. I also have just carried a chain on the floor of the cab which isn't great either.
I mounted an ammo box on the rear fender where the caution triangle was originally mounted. It has worked OK but I'd love something a bit bigger. I have contemplated fabricating and mounting a box of some kind to the left side step into the cab similar to what Ptsg has done, as I also seldom, if ever enter from that side. Haven't done it yet though.
/ Toolbox for a 3515CH. Ideas? #6
I've usually just piled whatever I need in my fel bucket and go. Or, if I'm working away from home, I pile it in the back of the truck bed. Not as handy for sure, but it "works" I guess? But a pallet that I could set in the truck bed with everything mounted to it might be pretty handy to have. If I got to the point where I was tractoring away from home a lot, I may copy K5's project.
Cougs,
I would probably mount something to the right side step area if I had to. I can't get in from that side anyway, would have to be an Ethiopian fashion model to squeeze in from that side.
/ Toolbox for a 3515CH. Ideas? #7
I never did but always wanted to take a utility box and make it a trailer with a pto input for a generator/welder and air compressor and maybe a hydraulic pump.
Would have been nice for field repairs, now if we have too it's a couple of tractors or pickups with lots of tools tossed in and blocks and what ever else may be needed and usually a couple of trips.
/ Toolbox for a 3515CH. Ideas? #8
I like that plan Lou! That would be a fun project.
/ Toolbox for a 3515CH. Ideas? #9
I saw online where you can use a pvc pipe to fit inside the loader hollow tube. Cut out top portion of pipe, cap ends, then secure. I’ll try to find pics.
/ Toolbox for a 3515CH. Ideas? #10
/ Toolbox for a 3515CH. Ideas? #12
Interesting Idea. My luck it would always rotate upside down and I would dump all that stuff on the ground. Lol
Yeah I haven’t made one but if I did I would mark the top or something.
/ Toolbox for a 3515CH. Ideas? #13
Just as I was thinking how dang clever that idea was, you had to go and spoil the ride!
Lol, yeah, I wonder if there would be a way to notch something to keep it always "timed" to be faced upwards?
/ Toolbox for a 3515CH. Ideas? #14
Lol, Slim I just know my luck. It is a very clever use of otherwise wasted space though. Marking the top is a good idea as well.
The weight of the tools might just keep it level. Kinda like those silly hubcaps that don't rotate with wheel. :confused3:
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
2022 Ford F-150 Pickup Truck (A61568)
2022 Ford F-150...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A61567)
2025 Swict 66in...
JOHN DEERE 344H WHEEL LOADER (A63276)
JOHN DEERE 344H...
