homesteader13
Gold Member
- Joined
- Aug 26, 2017
- Messages
- 265
- Location
- North West Montana Northern Rockies
- Tractor
- Massey Ferguson 1755M. John Deere 420-c
Another advantage to the foam is it actually adds structural rigidity as well.
Another advantage.
I've heard of builders wrapping the structure before they add the metal siding. Then spray foam inside. This allows the removal of a piece of metal siding if ever needed.
Easy removal - like a wind storm? No thanks, I want all the flimsy sheet metal glued and bonded by the foam. The last thing I want is a space for water to migrate, or praying the screw heads dont pop off leaving gravity to hold the sheet metal panels in place.
you can get spray foam insulation sprayed in (parts and labor) for right about $1.00 per square foot per inch of thickness.
IE, 500 sq feet 1 inch thick would run $500.00
And 500 sq feet 6 inches thick would run $6000.00
You are correct, I must have fat fingered it, I wonder if I can go back and edit that post?Hmmmmmmmmm,,,,,,,,
My calculator says 6X $500 = $3,000,,, instead of $6,000,,,![]()
Not sure about Canada, but in most of the US, you can get spray foam insulation sprayed in (parts and labor) for right about $1.00 per square foot per inch of thickness.
And 500 sq feet 6 inches thick would run $3000.00
R value for foam is way higher than the equivalent of same thickness of fiberglass batts.
Since my shop walls in the Northern Rockies are 12 inches thick I went with fiberglass on the walls and 2 inches of spray foam on the roof and peaks.
This also acts as a vapor barrier and controls moister and condensation.
Yes ventilation is definatley important, perfect example is in RVs because they are so airtight that they will actually have humidity issues in the WINTER to the point that they can get condensation on the inside walls.Not arguing at all.
Actually R value for fiberglass is higher than foam once you go past a couple inches.
Again, the building "must" breathe. So you either need air transfer thru the walls or ceiling, or you need a powered system to control moisture and condensation.
It's a vicious circle.![]()
