Dozer size for remmoving 5' diameter stumps and hill leveling
   / Dozer size for remmoving 5' diameter stumps and hill leveling #12
I'm thinking more like a D1000............ For big stumps I'd rent the biggest excavator with blade I could find, or something like this>>> Removing stumps the COOL way! - YouTube
I’ve seen that before and I’d love to have one and an excavator to go with it. That’s so much better than digging with the bucket. Picking up the pieces would be a pain but most of the dirt stays in the ground and doesn’t make a big hole and the pieces are pretty dirt free that burn easily.
   / Dozer size for remmoving 5' diameter stumps and hill leveling #13
If you have lived a good clean life you should be able to get an explosives license. You can use a tractor auger to drill through the stump and then use an inexpensive explosive like anfo (basically fertilizer and diesel) to quickly remove the stump. When I was young the feed stores sold dynamite to use on stumps. Probably a lot cheaper and more fun than a big dozer.
   / Dozer size for remmoving 5' diameter stumps and hill leveling #14
Douglas for stumps have big roots, 3-4 years old is a very fresh stump with little or no decay. A 5' diameter stump makes a really good tail hold for high lead or skyline logging. It's going to take a big dozer to push it. Years ago while working for a timber company on a road location survey, the cat skinner and his pitman got their D7 stuck in a side hill swamp hole. After pulling about 7 18" alders out in one go we found about a 3' fir stump up the hill a ways. It was probably about 20 years old. It held to winch the cat out of the mud, the winch cable was sparking from the strain, we were standing a long ways out of range of that thing let me tell you.
   / Dozer size for remmoving 5' diameter stumps and hill leveling #15
Not sure if you meant 5 inch stumps or 5 foot stumps.
Pine and Fir trees have long root systems but are very shallow and run just under the surface along the ground (pretty easy to uproot and push over) and are not deep rooted like hardwood trees in the midwest. (At least in the Pacific Northwest and Northern Rockies)
I have properties in both places.
For my evergreens in Northwest Montana I am able to use my 1944 John Deere 420 crawler ~ that boasts a 2 cylinder gasoline engine and push over anything 2 feet diameter or less in 1-10 minutes. Anything bigger and drill some holes and fill with diesel a few times and burn them out, or if I'm in a hurry or want to have a little fun with it, auger bit and a fuse and special ingredients...
Screenshot_20200808-005505_Video%20Player.jpgScreenshot_20200808-005901_Video%20Player.jpgScreenshot_20200808-005942_Video%20Player.jpg
   / Dozer size for remmoving 5' diameter stumps and hill leveling #16
Mickey has good input. Being that you are in western Washington, your are in timber country. Big stumps are a challenge to remove . i used to "shoot stumps" . We were building logging roads in the coast range and still in an old growth economy. Any fool can blow a stump to smitherings and leave a BA crater. That is not what you want to do. You want to split them with a blast. If you do it right it is split in thirds and then a larger dozer can push the pieces out. You have a minimal hole to fill but you will have a hole and not a crater.
Messing with powder is not child's play even if you can qualify for an explosives's handler card.Modern road builders have been using excavators to pioneer roads because of insurance, accuracy and speed. I could tell you how to shoot stumps but that is really what I don't recommend. I suggest you contact some locals through the logging supply shops. Tell them that you have some big stumps you need help with. Pushing around big stumps with a small cat is foolhardy. Digging stumps out with a larger excavator is really the way to go. You need to consider what you will do with your stumps when done and how you are going to fill the holes and compact them. You could hire it out safer, quicker and better than you will messing around.
   / Dozer size for remmoving 5' diameter stumps and hill leveling #17
5 inch stumps are nothing to a JD650 or a D4. Just cut the roots on one side in the first pass and push out. Bigger stuff like 10+ inches you will bounce off and you need to cut more. Its better to push out trees not stumps...if you have the option, dont cut the trees just push them out, they will be top heavy and gravity will be your friend.
I will push out 5 inch trees with my M59 all day long without much effort.
A 10+ ton excavator with thumb will make short work of the stumps and would be my first choice. A 15+ ton crawler loader works good.
   / Dozer size for remmoving 5' diameter stumps and hill leveling #18
View attachment 665564View attachment 665565View attachment 665566
Those are some pretty cool pictures!!! Do you have a youtube channel?
   / Dozer size for remmoving 5' diameter stumps and hill leveling #19
D9 with root rake tilt blade and ripper should work nicely.
Skid Steer Attachment (A55787)
Skid Steer...
Year: 2012 Make: Audi Model: Q7 Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 161335 Plate: B... (A55853)
Year: 2012 Make...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
Bobcat 60" Skidloader Bucket Broom (A50775)
Bobcat 60"...
(10) Rolls Hot-Dip Galvanized Field Fence (A53316)
(10) Rolls Hot-Dip...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
