Blew a hose, should I replace them all?
/ Blew a hose, should I replace them all? #1
FreedomFamilyFarms
Auburn, IN
Kubota B2710, Toro Z Master Commercial
I have a hole in one of the 4 hoses on my loader valve. Should I just replace them all? Planning to have this tractor a while.
/ Blew a hose, should I replace them all? #2
It depends.
Did the hose blow from old age or was a hole worn in it? If it was from old age then yes, replace them all. Otherwise, replace only the one that needs replaced. Plus, check all hoses for wear spots and protect them.
/ Blew a hose, should I replace them all? #3
Buy the parts. Concerning old age - A lot depends on your mode of operation - if you always operate close to your home base and your not running a money making operation I'd "go till they blow".
My M4700 blew a leak in 1 about 9 years ago. Then a couple more leaked over the years and recently I had to replace a 4th, but I'm always within a few hundred yards of home and its personal use only.
/ Blew a hose, should I replace them all? #4
I have a 1998 New Holland 555E loader backhoe with at least 30 hoses. I've replaced most of them at least once, a few as many as three times, and there are still a couple that are original. You never know when a hose is going to blow, or why. Replacing 3 other hoses because one of them failed does not mean that the new hose will last any longer, or that the original hose had any issues.
If you do decided to do it for piece of mind, keep the original hoses. There is nothing wrong with them and if one of the new ones goes out on you next year, you can always put the original one back on.
/ Blew a hose, should I replace them all? #5
I wouldn’t. Replace the blown hose and move on.
/ Blew a hose, should I replace them all? #6
Probably....
Over 2 years I replaced 5 out 6 backhoe (bend at the boom) hoses - finally got smart at the 1 and did 2 at the same time.
Since all 6 had flexed exactly the same number of times - and all failed at the bend - I would next base it on similar life.
/ Blew a hose, should I replace them all? #7
If sunlight or abrasion has shortened the life of your hoses, when you take them off would be a good time to slide put some nylon protective hose sleeve on over the hoses.
For a small tractor 1" diameter ought to do it. Maybe even smaller, but it has to fit over the fittings. Typical prices are about a dollar a foot. I figure it will double the life of a hose. Use zip ties to hold it to the hose fittings.
I got it at Amazon, and now keep a supply in the tractor shed:
Electriduct 1" Nylon Protective Hose Sleeve - 25 Feet for $27.
rScotty
/ Blew a hose, should I replace them all? #8
It depends.
Best advise here so far.
/ Blew a hose, should I replace them all? #10
Over a year or two period I wound up replacing all hoses on my old Kubota L2900, doing them all at the same time would have limited the pain to one event.
/ Blew a hose, should I replace them all? #11
How hard are the hoses to replace? If the location, fittings or routing is tough, it might be easier to go ahead and do them all at once. Otherwise, if it is a random failure I would just do the one.
At work, we blew the engine in a forklift. While the engine was out the mechanics wanted to replace the hydraulic hoses. They looked bad and with the engine out it would have been a piece of cake. Naturally, they were denied and the hoses blew less than a month after putting the engine back in.
Doug in SW IA
/ Blew a hose, should I replace them all? #12
Can you live without your tractor for a week or two? Ordering hoses on-line is a lot cheaper than having them made local. Often the local guy doesn't have the exact fitting and has to find a way to get around it or wait for parts from the warehouse. I have hoses that are more than 30 years old and never spent a day inside that still work just fine and others that blew. IMO there's no rhyme or reason why some hoses last longer than others.
/ Blew a hose, should I replace them all? #13
Well - 38+ years and never had to replace a hydraulic hose - knock on wood. I can see those that might be most likely to "blow". But one never knows. Fortunately - there is a business in Spokane, House of Hose. They can make anything needed - while you wait. They made up the necessary hoses for my Land Pride grapple.
/ Blew a hose, should I replace them all? #14
....At work, we blew the engine in a forklift. While the engine was out the mechanics wanted to replace the hydraulic hoses. They looked bad and with the engine out it would have been a piece of cake. Naturally, they were denied and the hoses blew less than a month after putting the engine back in.
Doug in SW IA
At least they saved money on the engine pull :laughing: . (Pay me now or pay me later....)
I don’t see any wear, just a random failure. I think I’ll just replace the bad one now and see where it goes. Thanks for the advice!
/ Blew a hose, should I replace them all? #16
208316 (A58375)
208316 (A58375)
2025 Polaris Ranger 1000 Side by Side (A64047)
2025 Polaris...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
INTERNATIONAL GRAIN DRILL (NEEDS REPAIR) (A63290)
INTERNATIONAL...
LILLISTON 2R ROLLING CULTIVATOR (A63290)
LILLISTON 2R...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
