BX2680 over heated.
/ BX2680 over heated. #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Did Some mowing today on the Kubota, and when I got back I realized that my coolant was boiling in my overflow.
Checked the radiator screen it was clear.
Checked the oil it was fine.
Checked the coolant and its full in the radiator but a little low in the overflow. It could be because it was spewing out when I shut it off.
Am I missing something?
Thanks
Dave
/ BX2680 over heated. #2
A little out of left field, maybe but... both my BX and GR fan belts will wear "skinny", sometime so badly that they can't be adjusted to be the proper tension. When this happens the fan still spins and looks like it's working, but is rotating too slowly to properly move air. I've pegged the gauge on a hot day due to that. Don't know if your machine is subject to that.
If you've already checked the fan belt... never mind...
Z.
/ BX2680 over heated. #3
Did you check air filter?
/ BX2680 over heated. #4
Shine a light through the radiator with the screen off and see how it looks.
On our BX2660 we will frequently have the radiator be plugged even though the screen does not look bad.
Blowing out radiator fins with air and or water seems to take care of it.
Aaron Z
/ BX2680 over heated. #5
+1 to that. Keeping radiator clean is #1 job to avoid overheating, particularly during mowing season. Rinse with hose or air when the engine is cool, of course. The screen doesn't stop the fine stuff.
/ BX2680 over heated. #6
Aaron Z
Good advice from Aczlan. I will make my usual comments on over heating BX machines. My BX2200 has always run "hot" when mowing with the 60" MMM in hot weather. Regardless of what I do it runs close to the red line if it is real hot weather and I mow for 1/2 hr or more. Compressed air is good for the radiator cleaning independent of how hot it is.
My firm belief is that the water pump is undersized on these machines. I want to swap in a water pump off of a larger 'Bota (like a B2150 or other 4 cyl if it fits) to prove it but just never had time/energy to do it. Flushing your radiator with a good chemical may help if yours has a lot of crud inside. All the BX I know of have this issue and I've heard of so many others I believe it is an across the board issue.
Aaron Z
Bingo! The radiator was plugged. Screen ever stopped it.
Thanks
Dave
/ BX2680 over heated. #8
Yep, that will do it. I make sure to blow my BX2200's radiator out every few mows. Either with the leaf blower or my air gun off off the compressor.
I've never had a blockage that bad...
/ BX2680 over heated. #9
The radiator on my BX had a bunch of fuzzy stuff in it, even though the screen was clean. I have a 3 foot long wand for my air blow gun. Went in from the fan side and got is all cleaned out, It never over heated, in fact the water temp gauge only barely gets 1/4 of the way up on the gauge, even when it's 80+ degrees out.IMG_20200628_144056745 (Custom).jpg
/ BX2680 over heated. #11
Radiator Genie - Water & Air Cleaning Wands for High Efficiency Cooling Systems and Radiators - Blow Out / Wash Out Kit Amazon.com: Radiator Genie - Water & Air Cleaning Wands for High Efficiency Cooling Systems and Radiators - Blow Out / Wash Out Kit: Home Improvement
I use these to keep the radiators and air filters clean. Use the water wand once or twice a year on the radiator. Air wand to clean the whole tractor or just before servicing like around oil filters. Cleaning off mower decks. Best price was from the Kubota dealer which was surprised. Use the air wand to sweep the shop floor out the doors. Water wand handy washing road salt from under vehicles.
/ BX2680 over heated. #12
I have washed my radiator and blown it out in the past.
But what I have found to be really effective (and gentle) in my case, with my BX2200, is using a shop vac. From the operators side.
It sucks the fins clean quite well. Just another option...:)
/ BX2680 over heated. #13
The radiator on my BX had a bunch of fuzzy stuff in it, even though the screen was clean. I have a 3 foot long wand for my air blow gun. Went in from the fan side and got is all cleaned out, It never over heated, in fact the water temp gauge only barely gets 1/4 of the way up on the gauge, even when it's 80+ degrees out.View attachment 664732
Double check your coolant level. Low coolant will leave the temp sensor high and dry so it will read lower than it should.
Aaron Z
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
AR500 Coyote Target (A65640)
AR500 Coyote...
