oosik
Epic Contributor
I have the Land Pride GS2584.   Mine was purchased, new, in 2013.   Yours is a 2020.   There is a VERY DEFINITE difference in the size between my/your scarifier cross tube.  My cross tube is - 4.5" x 4.5" with a tube wall thickness - 7/16".  My scarifier shanks appear to be heavier duty than those you pictured.   I looked at your shank pictures again.  Mine are MUCH heavier than yours and do not have replaceable tips.
Just a guess - Land Pride might have reduced the specs on this piece of equipment over the intervening years.
OR - maybe the jump from the 72" unit to the 84" unit necessitated a larger cross tube, shanks, etc - ???
I primarily use mine on my driveway. Scarifiers down about two inches. I've pulled it up against material so hard ( basaltic lava bedrock ) that the entire LPGS will jump up off of the ground. The only damage so far - the bright orange paint has faded to a "nasty" looking pink/orange.
When I use it on the driveway - I'm always going less than two miles per hour. Less shock load on the 3-point system.
I've also used it to improve the one trail on my property. Grapple lowered to push down the sage brush - scarifiers at their lowest setting - 4WD - off I go at just around two miles per hour. Raise the LPGS every so often to get the uprooted sage brush untangled from the tines and the two rear blades. Works like a champ.
My tractor is - Kubota M6040 @ 62hp.
