Harbor Freight tools that DO suck
Status
Not open for further replies.
/ Harbor Freight tools that DO suck #282
Harbor Freight Jack Stands Recalled.
item numbers 56371, (3 ton) and 61196, 61197 (6 ton).
a total of 454,000 jack stands made between 2013 and 2019.
Mine never sucked but HF thinks they do.......:D Like I stated in another comment, the set I got from Autozone are exactly the same. I wonder if Autozone's are suspect?
/ Harbor Freight tools that DO suck #283
The differences between the recalled ones and the OK ones are subtle. My 6 ton stands purchased earlier this year were not subject to the recall. As I understand it, the ones that were recalled are not a different design, it's just that the tooling on which they were made was worn, causing the pawl not to engage properly with the teeth.
/ Harbor Freight tools that DO suck #284
One HF stuff that sucks, their rubber tarp straps suck big time. One, they stink, Two, the don't last (fall apart) and Three, the hooks pull through the rubber part easily.
Total junk.
Theyæ±*e worse than that they are dangerous. When you are trying to hook the other end and it snaps that rubber club is coming straight at your face. If the hook twists loose itç—´ even worse :thumbdown: The Chinese white bungee cords work better last longer. No more of those black plastic things for me
/ Harbor Freight tools that DO suck #285
I based my comment on them after receiving a 'purple Herbie' from one. Nothing scarier than getting sucker punched by a black tarp strap.:mad:
/ Harbor Freight tools that DO suck #286
I've got a 25' DiaBlows black air hose that's showing cracks in less than a year.
I also have a 15' light duty air hose that came with the Campbell Hausfeld compressor I got from Monkey Wards in the early 80s that doesn't have a single crack.
/ Harbor Freight tools that DO suck #287
Got a grip on the Die-n-blows for sure. Chineseum rubba just don't cut the cheese.
/ Harbor Freight tools that DO suck #288
Again, not so much an item, but a policy. Why haven't they picked up on the order on the web and pick up in store craze? Even before this whole recent mess, most other similar store including NT were doing it. Even some of my grocery stores and places like Big Lots are doing it now. Sure there are times when I prefer to go in and browse, but there are times when I only need a few things, know exactly which items and don't have the time to wander around and wait in line. Plus it's often easier to apply coupons and discounts on the web and watch for errors in pricing so you can correct them. I hate having to wait for a manager because something rang up wrong or a coupon didn't scan right.
/ Harbor Freight tools that DO suck #289
Kind of hard to do "order on line" when the website doesn't know what items are in stock at the local store. I was looking for some cheap clamps last week. The ones I wanted, on sale, weren't in stock but they did have a couple of 'open box' specials that were longer than I needed that most likely wouldn't even have shown up on a website.
/ Harbor Freight tools that DO suck #290
The national Harbor Freight web site doesn't even list valid phone numbers for some of its stores. I was trying to call a New Hampshire store about an online order I'd placed, and it was clear from the get-go that the area code of the number wasn't a new hamphire area code (the number didn't work at all). I called another number for a Massachusetts store and that worked.
/ Harbor Freight tools that DO suck #291
I ordered a bunch of things this spring online in one big order (for the flat shipping rate). It took many weeks to get it all, in multiple shipments. Perhaps that's understandable with Covid virus issues. However some of the things I ordered were 7 dollies in two basic sizes. Every time I spoke with them they said the dollies were in stock and they didn't know why they hadn't shipped. So they "send an email" to the warehouse or something like that, but that's all they can from the phone. I am unlikely ever to order from them again online. Just too much work.
/ Harbor Freight tools that DO suck #293
To be fair, that could be said about lots of stores that will let you order online and ship to store. Lowes, HD & Walmart's sites are wrong often as not about whether a local store has an item in stock.
/ Harbor Freight tools that DO suck #294
Plastic dollies... these suck. No way they can take 200lb unless it is concentrated load over the wheels. Mine snapped in half with far less than 200lb on it.
2 Lb. Capacity Mover'''s Dolly
Yeah. I posted about that, maybe in the other thread. Summary: Those are for a big potted plant that you want to move to various locations on your patio.
I broke one immediately then tested the second one by stepping on it (180 lbs) and broke that one. Went back for an exchange and stepped on the store sample and broke that one. Junk.
Bought another wood one instead. The only weakness with those is the screws attaching the casters fall out so check them occasionally.
/ Harbor Freight tools that DO suck #297
Don't get these d-rings, they suck: 1/2 in. Forged Cargo D-Ring Anchor
"designed to withstand up to 10,000 lbs" ??? That has to be a joke. What was your experience with them?
I have their smaller size at the outer edges of a carryall platform (photo) just to tie down stuff so it won't fall off. They're ok in that application. I wouldn't use that smaller size for anything heavier.
/ Harbor Freight tools that DO suck #298
True but at least their software talks to each store to get an idea of inventory. HF seams to be using software made in China that has more limitations. I know when I go to the locations I usually shop at they have my phone number in the system. I have to believe it's in their main computer system and any store I visit would be able to bring it up. One would think that keeping track of inventory should also be possible. My guess is that since almost everything sold at HF is their own merchandise they don't see as big of a value keeping as tight of an inventory as, say Lowes does with brand name stuff they sell. Like the cheap warranty they sell to replace an item if it goes bad, maybe they figure that the cost of paying employees to itemize inventory, upgrading the software, and other expenses is more than just not worrying about it. Until recently the stuff they sold was real cheap.
/ Harbor Freight tools that DO suck #300
I bought 2 of them. On both, the d-ring itself had a little ridge left over from casting that they didn't grind down before zinc plating. With the ring under the bracket, the ring wouldn't flip easily back and forth, that ridge got in the way. Only recourse was to either grind the ridge down or put little shims under bracket to raise it a little to give the ring more space.
Status
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
Landhonor Hydraulic Logging Winch (A66285)
Landhonor...
