New BH70 backhoe on my Kubota B2601
/ New BH70 backhoe on my Kubota B2601 #1
noose
No City Slicker
None Yet
Ok, so I had a BH70 backhoe added to my Kubota B2601 since I have so many digging projects. It may be my imagination, but it feels like I have lost some lifting power from FEL in terms of lifting power. I feel like when I reached max lift before the engine would bog a little but I don't get any bog now - it just refuses to lift or curl if I'm trying to lift too much or take too big of a bite. Is it my imagination or does adding a BH like this have a tendency to do this? I'm going to call the dealer and ask but I'm sure they will tell me it is my imagination.
/ New BH70 backhoe on my Kubota B2601 #2
Have you checked your hydraulic level since installing your BH. If the BH runs off of your tractors hydraulics and it circulates fluid when connected, it is possible that your pump capacity becomes limited in the volume it can pump/supply to the entire system including your BH.
Also if the BH and lines for it required enough fluid, it is possible the pump is not getting the supply it needs—this can damage a pump quickly if air gets in the system.
One more concern, if the BH contained old possibly dirty fluid, as that fluid mixed with your tractors fluid and flowed to your common reservoir, you could have a blocked screen preventing the pump from getting sufficient fluid flow.
Start with checking the level of the fluid. Next try to drain a bit of fluid from the reservoir (yes much easier said than done) then filter it through a cloth to look for debris.
Have you removed the BH? How does the FEL respond without the BH connected?
Also if the BH and lines for it required enough fluid, it is possible the pump is not getting the supply it needs葉his can damage a pump quickly if air gets in the system.
Thanks for all the suggestions. I'll check the fluid again tonight. I did right after the dealer put it on but there's always that chance they didn't cycle it enought to get all the air out. Remove the backhoe and dig is a good suggestion. I'll do that next before anything major labor-intensive. Tractor has less than 100 hours on it and the BH was brand new so very unlikely to be dirty fluid/clogged screen.
/ New BH70 backhoe on my Kubota B2601 #4
Well I would tend to agree with less than 100 hrs and a new BH dirty fluid issues should not be present.
But that raises the low fluid question even higher, there are lots of hoses and several cylinders on a BH, thus lots of air pocket potential. It all should self bleed.
Good luck on it.
/ New BH70 backhoe on my Kubota B2601 #5
Noose, if you are still watching this thread, can you add BH70 to a B2601 "later" or is it something the machine needs to be ordered with? I'm ordering a B2601, dont need or want the BH now, but would like the option to do it later...
/ New BH70 backhoe on my Kubota B2601 #6
Other than the dedicated Kubota TLB model offerings, all Kubota backhoes can be added at the dealership either at the time of original purchase or after.
/ New BH70 backhoe on my Kubota B2601 #7
Good to know I can add it after instead of biting the bullet now, I appreciate the help Rick!
/ New BH70 backhoe on my Kubota B2601 #10
You will find an after delivery add will cost considerable more than one ordered delivered with the BH.
Ron
Is this only if the dealer does the install? If you have to pay them to transport the tractor to the shop, do the install, and deliver back then I can totally see that being true.
I'd like to think that the dealer could load the "crated" backhoe and subframe on your trailer and just complete the install yourself at home to actually save considerable $.
/ New BH70 backhoe on my Kubota B2601 #11
Buying the backhoe after the tractor purchase, is the same as buying any individual tractor implement.
With the initial large purchase, you as a buyer will have some pricing leverage, on a package deal.
Without that leverage, you will pay whatever the dealer asks for the backhoe, or you will not be buying a backhoe.
Depending on the brand, and size hoe, could be $1,000+ price difference.
/ New BH70 backhoe on my Kubota B2601 #12
Speaking from a dealership perspective I doubt many dealers would agree to install a backhoe start to finish at a customer's location.
Buying after the initial purchase would carry a financial penalty in most cases.
/ New BH70 backhoe on my Kubota B2601 #13
I just wanted to make sure it was an option later, unlike the BX where its machine specific from my limited understanding.
the dealer doesnt have a BH70 in stock to package with the machine anyways or I'd prob give it more thought to add right now. Getting the tractor to them later isnt a big deal. I think I will have to bring it back anyways to have them install the rear remotes which also arent in stock. But they actually have a 2601 there in the crate, and not many dealers around here do. kind of crazy. Thanks for all the input guys.
/ New BH70 backhoe on my Kubota B2601 #14
Nothing prevents you from negotiating the backhoe now and folding it into whatever finance deal you may be getting. Surely the interest rate will be better bundled with the tractor. If you can transport the tractor that's in your favor, be sure to mention that.
/ New BH70 backhoe on my Kubota B2601 #15
I was told that if the "accessory" has a serial number, that it must be physically present upon delivery in order to include it with the financing package. So both the snow blower and backhoe are not able to be included. It's easy to go nuts with zero percent money so maybe its for the better ;)
/ New BH70 backhoe on my Kubota B2601 #17
Could the OP or someone address what's involved in adding the backhoe in terms of other necessary mods? Like seat and maybe ROPS. I was looking at my B2601 and adding a backhoe seems like it would come with lots of extra work/costs.
/ New BH70 backhoe on my Kubota B2601 #18
From what the dealer told me two things happen at after delivery install. The BH itself costs more and if dealer installed either way there is no install cost. Not all dealers may offer free install. I looked at a B model before deciding to by the BX which comes with the BH which is not an option. I did not see enough difference in capability to warrant the additional cost of the lower end Bs and I needed the BH.
Ron
/ New BH70 backhoe on my Kubota B2601 #19
Adding a subframe mounted backhoe to any tractor is a labor intensive operation whether it is installed when the tractor is assembled or after the fact.
the only Kubota backhoes that are currently factory installed are on the BX23S, B26, L47 and M62.
/ New BH70 backhoe on my Kubota B2601 #20
Wouldn't installation require a new swivel base for the seat and perhaps a new seat? Does the ROPS need to be changed as well?
2018 Ford F-150 4X4 Pickup Truck (A61568)
2018 Ford F-150...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
New/Unused Landhonor 8ft X 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61568)
2016 Volvo VNL T/A...
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
