Grapple Recommendations for a Compact Tractor 48"-54"
   / Grapple Recommendations for a Compact Tractor 48"-54" #11
Precision manufacturing now also makes a grapple called the mini 322. That and the wicked 55" are the only 2 that weight 250lbs or so...the rest are 400lbs and up that I've seen.
   / Grapple Recommendations for a Compact Tractor 48"-54" #12
I have a MTL 54". I've only had it about a month but it seems solid and does what I need it to do. It weighs around 400 lbs though, which is about 1/3 of the lifting capacity of your T233- a concern which you've already mentioned.
Somebody mentioned the artillian model;
Sectional Grapple - Artillian
They are priced comparable to mine, and are a lot lighter; the grapple is only 90 lbs, if I read the specs right. The single grapple doesn't look as wide as you'd like though. You could also just buy the top grapple and mount it on your bucket or pallet forks.
One downside to mine which may be normal or could be specific to the MTL, is that it won't close down very tightly on small trees. I plan to make an adapter from a couple of old ATV tires which I salvaged from my trash.
   / Grapple Recommendations for a Compact Tractor 48"-54" #14
One downside to the LandPride though is the price... twice what you will pay for some of the others. For the average user like me, it's hard to justify that extra expense.
   / Grapple Recommendations for a Compact Tractor 48"-54" #15
I wonder if the artillian rake/grapple would fit a non-artillian frame.
   / Grapple Recommendations for a Compact Tractor 48"-54" #16
   / Grapple Recommendations for a Compact Tractor 48"-54" #17
I have the mtl 48 and it has been great.
I will try to post a picture of one solution to improve the bite on small trees that逞エ worked for me.
I guess I can稚 add pictures from my phone, I welded a piece of 3/8 plate between center bottom teeth with v notch to fit top center tooth. Will even grip vines now
Saplings are fun now
   / Grapple Recommendations for a Compact Tractor 48"-54" #18
The MTL is well built for the money. Their website says the 48" weights 360 lbs.
I would like to see your modifications.
Here is the sticky on photo posting.
https://www.tractorbynet.com/forums/photos/107314-photo-posting-how.html
   / Grapple Recommendations for a Compact Tractor 48"-54" #19
Thanks for the help with pictures, I’ll get a better one to show the modification
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2022 Caterpillar 300.9D Mini Excavator (A55973)
2022 Caterpillar...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
