Thinnest hay field you ever bothered to bale?
   / Thinnest hay field you ever bothered to bale? #1
PROFarms
Gold Member
Devon, England
International 444, Yanmar YM169d, Cub Cadet
What’s the thinnest crops any of you have ever bothered to cut and bale? Interested to know if anyone else bothers cutting they little grass
Been told today I was mad for cutting a field when I did! Grass was barely to the top of your boots in some parts but had all gone to head thanks to the hot weather we’ve had lately. Normally we get around 75-100 small bales off this piece.
Only decided to do it in the hope of a half decent second cut and grass is scarce this year already!
Be baling it tomorrow at just under an acre be interested to see how much is there but I’m not hopeful for much.
   / Thinnest hay field you ever bothered to bale? #2
Perhaps not to bale, but to control weeds. I've a 10 acre field with a thin second cut. I waiting to just mow it for weed control.
   / Thinnest hay field you ever bothered to bale? #3
I still cut what's left of my hair, but I don't bother to bale it. It's pretty thin, but that's probably not what you meant.
   / Thinnest hay field you ever bothered to bale? #4
Run with what you got I say...
Tell you naysayers that it does not really matter; hay costs are proportional to the amount of grass grown. If it is thin, you spend less money on fuel and baling twine, so what does it matter?
   / Thinnest hay field you ever bothered to bale? #5
Land that gave one 4x4 bale per acre.
   / Thinnest hay field you ever bothered to bale? #6
That is pretty darn thin. I average (7) 4x5 bales per acre here, but a bale of hay is better than no bales of hay, because come January, there is even less hay growing! :)
The grass is pretty thin this year though, at least here in Maine. I mow the sides of the road and even where the grass typically is the thickest, I am traveling 2 gears higher than last year!
Well baled the field last night and got 21 square bales off of hay off it weighing in at about 50lbs each
   / Thinnest hay field you ever bothered to bale? #8
Done some fields that were 10 4x4 an acre, some that were 2 4x4 and acre. Unimproved land yielding very poor.
   / Thinnest hay field you ever bothered to bale? #10
If it痴 really high quality then I would think worthwhile. It also may create a better situation for the next cutting. It sounds like your situation required it.
3 1/2 BLACK CONDUIT WITH ROLL OF FABRIC INNERDUCT (A50854)
3 1/2 BLACK...
1043 (A50459)
1043 (A50459)
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
1998 CATERPILLAR D5M PIPE LAYER (A50854)
1998 CATERPILLAR...
