Spydertractor
- Joined
- Jul 9, 2020
- Messages
- 10
- Tractor
- Ford 6600
Hi all
I hoping some kind expert out there might be able to help me with a problem I am having with my power steering. The details are as follows;
Ford 6600 tractor
Over the last year or so the steering has gradually become more difficult, needing more effort.
It is easier to turn to the left than the right and it turns further to left than the right.
From full left lock to full right lock the steering wheel makes 2.5 to 3 rotations
It appears to be no easier to turn the wheels when the front is off the ground. It is impossible to turn the wheels manually when off the ground.
The reservoir continuously needs topping up (by not by much) but I can not see any leaks. I have topped up with universal tractor oil.
When I used it yesterday for topping, the steering got tighter and tighter so that I had to make multiple small turns. After about 2 hours work, I could hardly turn it at all. The pump/reservoir was very hot to touch and the oil looked like it was nearly boiling.
Today, the steering is better than at the close of work last night, but with the same long standing problems.
Is this a problem with the pump or something else?? I have not changed the filter (ever) but it must be more serious than that?
I did not want to spend on a new pump if that is not the solution.
I will be very grateful if anyone can advise.
Many thanks
Ford 6600 tractor
Many thanks
