Smokeydog
Elite Member
From my recent 400hr super UDT oil change, new filters, and new pump suction line replacement could not tell there was any air to bleed. No noise, no jerking, no problem. ~7+ gallons to refill system. 5 gallon buckets of new oil.
Oil supply to the pump comes from lower right hand side of the tank at the filter housing. It would take an awkward position to lose oil supply. Another post reported they had damaged that filter housing by ground debris.
Air in your system now is getting in somehow. Rubber elbow likely suspect. Backhoe leaking down when parked might be letting air leak in. Note any exterior leaks from lines, fittings or cylinders? Didn’t you recently add a thumb valve?
