TuffTorq K46 Repair Guide with Pictures
   / TuffTorq K46 Repair Guide with Pictures #981
Re: TuffTorq K46 / John Deere L110 Transmission Repair Guide with Pictures
Old and long thread.
Are many using the thicker viscosity oil that was mentioned... the 75-90?
i was going to do a rebuild however i contacted tuff torq and now they say you cant buy individual parts, have to get the whole kit according to the person i was talking with.
I did find a spring rebuild kit online for the pump and motor. Would this be worth doing?
I changed the oil in my 2007 x300r multiple times and it made no difference. Then I tied some 80w90 gear oil that I got from Wally World for 7 bucks a liter and it did make a difference. Instead of running 10 to 15 minutes before the machine refuses to ascend any type of incline, I now get about a half hour, depending on conditions temperature and terrain.
It worked okay that way until a few days ago when the axle broke (not related to the thick oil, I fairly certain).
   / TuffTorq K46 Repair Guide with Pictures #982
I just sprung for a new K46 so I can sell the x300r, which should be okay for someone with a flat lawn. The new tranny was $900 (CAD) with tax and a local repair shop had it in stock. I installed it yesterday. Although the case was a slightly different shape, I was able to install it using spacers to lower the unit slightly. The linkage, drive shafts and pretty much everything else was the same as the original, except that there was no provision to install the breather tank (I'm assuming it doesn't need one since it did not come with the new K46 and there was really nowhere to mount it).
The problem now is the drive controls are reversed. If you press the forward pedal, the tractor moves in reverse, and vice versa. Kind of weird! There is only one drive control linkage so there's nothing to reinstall incorrectly.:confused:
   / TuffTorq K46 Repair Guide with Pictures #983
sorry you had to buy a new one. If your old one isn't full of ground up gear teeth inside, it would have a bit of "core" value. Maybe about $40-50 dollars US.
   / TuffTorq K46 Repair Guide with Pictures #984
You have some homework to do. You'll have to disassemble the transaxle and flip the wedge block. These units are made to run in either direction.
https://www.tractorbynet.com/forums...r-guide-pictures-post4106942.html#post4106942
Yes, had to do that with the previous tranny. When I took it apart and installed a drain plug, I put the wedge in backwards. I'd rather not crack this one though, since it's brand new. Guy at the shop said he'd take it back on exchange for the correct part. Guess I should have checked first when I assumed that because it was a K46 and looked almost the same, that the drive was in the correct direction.
   / TuffTorq K46 Repair Guide with Pictures #985
I asked about returning the core where I bought it but they said they didn't want it. I guess if it were an actual John Deere stealership, they may have given me a rebate for the core.
   / TuffTorq K46 Repair Guide with Pictures #986
put it on craigslist or ebay
   / TuffTorq K46 Repair Guide with Pictures #987
Good idea. Last time I had it open there didn't appear to be any damage and there were very few filings on the magnets.
   / TuffTorq K46 Repair Guide with Pictures #988
I had to replace one and John Deere dealership did not want the core.
   / TuffTorq K46 Repair Guide with Pictures #989
I have a newer husqvarna ts348 garden tractor with the diff lock, is this the tranny/diff that i have? And does the fluid need to be changed at certain hours? im at 60 hrs , this is summer #2: of mowing.
   / TuffTorq K46 Repair Guide with Pictures #990
No your trans is a K66 see TractorData.com Husqvarna TS 348XD tractor information Do not think 99.9% sure NO "Garden Tractor" has a K46.
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A56129)
2008 AAR MOBILITY...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2014 TRAIL KING JBTR-38 (A55745)
2014 TRAIL KING...
Misc. Network Switches (A53425)
Misc. Network...
1989 CATERPILLAR 963 CRAWLER LOADER (A52707)
1989 CATERPILLAR...
