Rear hitch and weights
/ Rear hitch and weights #1
spechols
Central, PA
Power Trac PT425
Made a rear hitch adapter for moving the trailer with the PT 425.
Should make driving forward with the trailer much easer.
It also works for mounting the weight bar if I need it.
Can hold 400 lbs on the weight bar.
Doubt I will ever need or want that much weight in back.
/ Rear hitch and weights #2
Nice job! Maybe I will do that with mine someday.
/ Rear hitch and weights #3
Nice, now get to work on a 3pt hitch, and make extras to sell once you get it right.:thumbsup:
Plan to sell all my 3pt hitch stuff now that I have the PT425. Need to also sell the other tractors.
/ Rear hitch and weights #5
I went the opposite route and welded a 2" receiver to my spare QA plate. I use that to move my car hauler, boat trailer and log splitter around the place. Works great.
The things I do tow behind our PT425 are a lawn sweeper, Rubbermaid cart, sprayer, dethatcher, and plug aerator. They all have pins that drop through the stock PT hitch. I would like to weld a couple more single hitch tabs onto the rear of the PT on each rear corner. That way I could tow my sweeper offset to one side about a foot. And if I ever need to mow really large areas in the future, I could get an offset 60" pull-behind mower deck or two and do 14'6" passes! :)
I also have a front hitch I made but pushing the trailer with a load gets old. I have to get through three gates. My skills are getting better but I am much better pulling it behind. Then I switch to the front hitch to lift and dump. That least that is still my plan.
/ Rear hitch and weights #7
Ahh. I get it. I don't push anything through gates either, unless it's the mower deck. :thumbsup:
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
2021 Komatsu PC210L Hydraulic Excavator (A66734)
2021 Komatsu...
2014 Dodge Grand Caravan Van, (A66738)
2014 Dodge Grand...
Unused 2021 MK Martin Axis 5-6 Hydraulic Took Arm Tractor Attachment (A66734)
Unused 2021 MK...
WACKER NEUSON LTN6 LIGHT TOWER (A65056)
WACKER NEUSON LTN6...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
