Hose Replacement
/ Hose Replacement #1
stump54
Bladen County North Carolina
MF-2607H, MF-1540, MF-GC1710, Ferguson TO20
What is the conventional wisdom on replacement of hydraulic hoses? Replace at set intervals or only when needed?
/ Hose Replacement #2
when needed
/ Hose Replacement #3
If you have hose showing heavy wear or such good to replace before failure.
/ Hose Replacement #4
IMO...The prudent thing to do is "be prepared"...have at least a couple of generic, common hoses in a couple different lengths (a bit longer than most on a typical machine) and an assortment of fittings and adapters that should work on typical applications...
if a hose goes out when in the field it will pump fluid the entire way back to the barn...
One advantage of replacing working hoses based solely on age etc. leaves an operator with exact emergency replacement hoses on hand...!
/ Hose Replacement
Thanks, all
Do places that fabricate hoses, such as NAPA, have the specs for hose size/length/fittings/etc, or will I need the original?
/ Hose Replacement #6
Bring the old hose with you...
/ Hose Replacement #8
You'll need the original.
/pine's idea of a generic replacement is a good one.
/ Hose Replacement
I was surprised to see this particular hose is attached with hose clamps. I would have thought pressure too high for that.
Looks to be 7/16 ID, non-braided.
Any idea of a source for this type hose (TS, NAPA, etc)?
/ Hose Replacement #10
That looks like a molded hose, as often used for coolant. What was it connected to?
/ Hose Replacement #11
Pumping fluid depends on what hose goes!
Yes if it is the supply or return lines for the tractor or a powering steering hose or a supply/return line on a hydraulic control valve or designed to provide constant flow for an implement (such as a wood splitter or backhoe). But if it is a line to a set of remotes or a line down from your loader valve, these will only leak as you redirect hydraulic flow to that function.
/ Hose Replacement #12
View attachment 662132View attachment 662131
I have seen return or tank lines and a few suction lines use hose clamps. These usually do not have a high pressure demand. Really high pressure is typically down flow from a valve that redirects the flow. These are often much higher than even the pressure side of the pump.
Molded hoses are usually a dealer item unless you can route the hose in other places and still get to the other connection location without risking damage to the hose.
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A8HK003056 (A61165)
2017 Mitsubishi...
John Deere 5525 (A60462)
John Deere 5525...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
