3-Point Hitch 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size
   / 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size #1
psucmu
Mill Spring, NC and Supply, NC
2014 LS XR4046 FEL & Backhoe, 2022 Kubota BX2380 FEL & 60" Belly Mower
Hi all,
I have a 2014 LS 4046 which is about 5 hours away at our property. The two brackets that attach the 3 pt hitch to the axle/frame need replaced, i have the replacement parts on site. It consists of two brackets and two bolts for each two brackets. I'm picking up some impact sockets and am heading over there in a couple of weeks. If anyone owns a similar tractor and can get me the socket size it would be greatly appreciated.
Thanks
   / 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size #2
Hi all,
Thanks
I have an identical same year tractor. I'll measure it and get back with you.
   / 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size #5
Curious, did the bolt just come loose and fall out or did it break off?
Also, I believe the bolt size is M14x2x35L
   / 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size #6
He didn't say anything about that. He's replacing the brackets. All the hardware is on site and he wants to have the right tools available when he gets there. Yes, I see the picture only shows one bolt, however ....
Me, I'd had just bought a whole metric and SAE set if I didn't already have them.
   / 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size #7
I read and fully understood the original post. Replacing the brackets, having the parts, distance away, etc. The reason I asked about the missing bolt is just that, he didn't mention it so that's why I asked. I wanted to know if something specific happened or whether others should be aware of an issue or defect.
I also could said to buy a set of sockets but the question was what is the socket size.
Hi, I didn't realize there were additional comments to this thread. To answer: I ordered replacement brackets and bolts for both sides.
On the one side, one bolt is loose, the other is snapped off. I'm still going to have to remove the bolt that snapped off. On the other side, the part of the bracket that attaches to the three point hitch is broken off.
Not to complicate matters, I have a Milwaukee 3/4 Drive M18 Fuel impact wrench. Most 3/4 inch drive impact socket sets that I've seen don't include sizes down to 22mm. I'm buying a one off, hence the need for the size.
   / 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size #9
Thanks. View attachment 662449
What I found interesting is how your brackets are different than mine. The brackets on my tractor are all one piece. The brackets are part of the lower frame stabilizers that are painted blue. I don't know if frame stabilizers is the correct terminology or not but they run toward the middle of the tractor where the front bracket for the backhoe is located. There are two main bolts like you have pictured, two lower bolts in the case at the differential then it is bolted to the tractor at the front of the bracket. I just thought it was odd the same year and model of tractor would be different.
   / 2014 LS 4046 3PT Hitch Frame Bracket Bolt Head Size #10
My mistake, there are only the two main bolts in the rear. No lower bolts.
2007 CAT 904B (A47384)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52128)
2024 BCL...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
UNUSED FUTURE MINI...
RoGator RG1100C (A52128)
RoGator RG1100C...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
