WHy the shade on flux core?
   / WHy the shade on flux core? #13
To me it has more to do with application than anything.
If I was welding flat, or welding horizontal, I would run spray-arc and just lay in the weld.
But on mirror welds, I would switch to Pulse Welding and carefully put in the weld. That gave me so many options, up, down, horizontal, flat...but it was not like I was making hundreds of feet of weld in a day either.
But on vertical-up welds: there was nothing better than flux-core. Holy smolies I could lay in weld after weld with that, and get something done in a day. Try that with pulse welding and you would be there until retirement.
So it depends on the task at hand. There is no perfect welding application, you adapt and overcome by using the most productive process for what you are doing. And it is not hard with a versatile machine. Have a bottle of 75/25 on hand, and a bottle of 95/5 on hand, and it gives you all those options.
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2016 Dodge Caravan (A50324)
2016 Dodge Caravan...
1999 John Deere 7810 4wd Tractor (A52128)
1999 John Deere...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
UNUSED AGT SDA-140W WHEEL LOADER (A51243)
UNUSED AGT...
