Box Scraper What kind of box blade is this thing?!?
   / What kind of box blade is this thing?!?
Mtnviewranch - very similar but way older than that manufacturer and a lot more heavy duty.
Sportsman I definitely agree with you. Has to be one of those. I was even thinking the MF18 but couldn稚 find any with hydraulics. Thanks so much for taking the time and pulling up the parts manuals. Still can稚 find an operator manual for any of those models. You would think they would be available online somewhere.
   / What kind of box blade is this thing?!? #33
I am not sure if they ever made an operator manual for these. Maintenance is to clean it off and when the cutting edges or points get worn replace them. What do you need to know?
Sportsman just was looking to see exactly how to Lock hydraulic mechanism when rippers are down
   / What kind of box blade is this thing?!? #37
I believe that the way the linkages are the cylinder sees very little stress when the scarifiers are down, hence the complex linkage. However I would not raise or lower the scarifiers with them in contact with anything, not sure if the linkage would handle it.
Thanks again sportsman very good to hear
   / What kind of box blade is this thing?!? #39
Gannons are that way. Things bend or break if not latched in all the way down.
Anyone know where I can get a replacement scarifier? I cant find any on the internet with such a heavy rear angle. I need the one with the rear angle, the other one is a replacement that came with the blade. It sticks way out and hits my tractor when I raise 3 point to top position.
Here is a small test run, had to take out a hump where I couldn't mow. Only used it for about 10 mins I am very please so far
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
