Good morning!!!!
   / Good morning!!!! #114,262
My experience with Uship to ship a baler to Ohio was not good, only 2 quotes, one with no experience and high, the other set a short deadline and was high. They later came back even higher. Maybe up east coast has more participants.
I borrowed a trailer and took it myself. Now dad is out of the cattle business. He sold the round baler.
   / Good morning!!!! #114,263
Good Morning!!!! 78F @ 4:30AM. Plentiful sunshine. Hot. High 104F. Winds SSW at 5 to 10 mph.
Congrats on the bumper tomato crop Kyle!:cloud9: What did you do different this time around that led to such a resounding success?
Thanks for the suggestions, Ron. I'll see if I can't chase something down during today's siesta time. Aren't the female bluebirds always somewhat duller in appearance?
How fortunate excavator konked out on dry land, Eric. Could something that shouldn't have got wet? They only let us move 100 cubic yards of dirt here before we have to pay for a permit and submit all kinds of paperwork explaining what is to be done. So far I've managed to keep the projects small enough to stay under that limit, but I think I'll have to sharpen my pencil for the new shop building permit.
Sorry Coco's having such a rough time, Billy, but at least she's enjoying the new food and it sounds like you're doing everything you can. Hope she's back to her old self in no time.
That blueberry pie, and especially the ice cream, sound delicious, RS. Sounds like the Squeak might not have been the only comatose diner yesterday?
Eleven new CV19 cases here in the county just yesterday, Bruce, pushing the total over the hundred mark. Only three in the hospital though, and still holding at one death. But it does show that people are letting down their guard a little too early.
Glad you have a new friend, Drew. There but for the grace of God. I worked for a nondestructive testing firm one summer while I was in college, and was certified in magnetic particle and liquid penetrant testing. But x-ray and ultrasonic testing were used to find defects in critical work like pipelines and heavy structural welds, and a summer was too short to gather the necessary skill and experience for those certs. Later on I'd learn that good as they may seem, sometimes the only real way to be certain about a defect is to cut something up, and often times one out of ten was randomly sampled that way just to make sure nothing bad had crept into the production processes. TIG, or more accurately Gas Tungsten Arc Welding, uses an arc between a tungsten electrode and the work, and inert gas shielding to prevent oxidation. That's the one most used for aluminum and stainless steel, and that requires extra skill to manipulate the hand fed filler wire. MIG, or Gas Metal Arc Welding, uses an arc between an automatically fed filler wire and the work, and may or may not utilize a shielding gas. Shielding compounds that break down to form a gas can be incorporated into the hollow core of the filler wire, or CO2 or argon/C02 mixes can be used for shielding when a cleaner weld appearance is desired. GMAW can also be used for aluminum and stainless steel, but it's more involved to switch over from mild steel, so you usually only find it applied to those situations when there's a lot of that work to be done. GTAW, on the other hand, can just pick a compatible filler material, and flip a switch to go from AC to DC current and be off to the races. I put a lot of weld metal into that old tractor, and I hate to think what it would have cost to pay someone to do that work for me, or how many trips it would have meant for someone to come out or me to haul it in to a shop somewhere. But almost all of it was GMAW, because my dexterity and eyesight just aren't good enough to get a decent result with GTAW anymore. If you're lucky, they put thumbscrews on your PCs case. Usta be I could open up my laptop to clean it out or upgrade the memory or drive, but these new ones either snap or are glued together, and there's nothing replaceable inside. Dunno how you're supposed to clean 'em, maybe blow 'em out with compressed air?:confused2:
I've used UShip twice, and not been impressed by the drivers either time. Both were for moving motorcycles, and neither had proper straps or knew where to place them to avoid damage. The great state of Kalifornia limits anything pulling a trailer to 55 MPH. That means there's often a big speed differential between the cars and trucks, made worse by kids in little rice rockets that like to play pinball with the truckers. So we get a lot of accidents in the big cities, especially during rush hour when everyone's in a hurry.
Knowing you as we do, Drew, it's a safe bet most of your housing and medical costs are being covered by good insurance policies, or at least I hope that's the case. And it takes a lot of worry about what's going to happen next, especially for your family that had to so quickly make those hard decisions. Hopefully the chemo will go easy on you and you'll be out of there in no time, and more affordable alternatives will open up to you when you need them.
Spent the cool of yesterday morning reclining under the van, installing a magnetic switch to detect when the transmission is in neutral. Had to disconnect one end of the drive shaft to do it, but I've had lots of practice at that. Then run a long wire back to the computer, where I was reminded I still have a couple of oil leaks to deal with on the transaxle and engine. A little solder, some heat shrink, and lots of zip ties to keep the wire safe and that job is done. Hopefully it takes care of that one persistent error code that keeps coming up, but only time will tell.
By the time I finished that, I was hot and hungry, so after lunch I switched over to getting the power system controller on the internet. Tried lots of things until finally late in the day I stumbled across a forum post that suggested the controller had to be power cycled before new settings would take effect. Then I found another post that said to pull out the cable from the hub to power cycle it because there's no switch to do it. Turns out that worked, and now I can view, but not change, the controller settings from a laptop or handheld, and the controller reports it is connected to the more capable OpticsRE software my contractor wants to use to monitor and maintain it. Would have been nice if they'd have dealt with this on their last visit, but once again, they were in too much of a hurry...
Fingers crossed for a good final inspection outcome today, but we still don't know what time the inspector will be here, and won't until they have their morning meeting and update their website. The contractor says he wants to be here for it, but then says he has a conflict in the afternoon...:confused3:
   / Good morning!!!! #114,264
Don, surprised to hear you get dust from Africa too, wouldn't have thought the wind blew in that direction, or does it circulate the globe first ?
Thats where many of our hurricanes originate.
Good morning! Much needed rain this morning which caused the FireWise to be canceled for today. 70˚F.
Yesterday was my first day in the covid era neighborhood gym. Only seven people are allowed each hour so it's easy to keep distance. Lots of wipes available and the gym gets closed and cleaned each hour. Face mask required except on aerobic machines in front of the gym where every other one is closed for distance spacing.
Nice haul on the tomatoes Kyle. Time to pull out the canning jars.
Ron glad you let the bird comb his feathers before you took his pic.
   / Good morning!!!! #114,265
Dust from Africa?? Well, the dust oughta be settled around here. I awoke to a downpour and just a little thunder this morning. The heavy rain has slowed to a light sprinkle, but the radar doesn't look like it should quit for quite awhile. My gauge already had 1.7" for today. So that's 5.41" for the month and 35.24" for the year and supposedly our ANNUAL rainfall should e 30.05. Yep, a very wet year, or at least the first half.
   / Good morning!!!! #114,266
Good morning all. 72 going to 90 today and the air is thick and wet.
Might be a good day to just trim the bushes out front.
Garage door springs are in, time to fix that so the missus can park her car out from the rain.
Had a little more than .5 inches of rain last night.
Gave the tractor a bath, it needed it.
Kyle - secrets for the tomato crop, my plants are slowly growing, not a tomato in sight, but we had a cold spring so...
Drew - Sounds like you are doing well. So many medicines short term, a few months and that should reduce.
RNG sounds like you are making good progress with the solar-too bad they couldn;t of sat down with you for a basic walk through and config
TXDon - good to see you can get to the gym, small steps forward can make a big difference.
I have a Cardinal alarm clock here, every morning it stops by to fight itself in my window. Would hate to be another cardinal in the area :)
Stay Safe and be well
   / Good morning!!!! #114,267
RNG.
"Fingers crossed for a good final inspection outcome today, but we still don't know what time the inspector will be here, and won't until they have their morning meeting and update their website. The contractor says he wants to be here for it, but then says he has a conflict in the afternoon."
Yep fingers etc. cross for :thumbsup: you certainly put LOT time $$$'s into project.
   / Good morning!!!! #114,268
Added protection for loader pistons and arms...dang rocks.
If I used expanded metal across the snow would have pack in causing lot less lighting for night time use.
   / Good morning!!!! #114,269
Good morning to all! Low of 64, only going up to 85 today. Slight chance (20%) of a t-storm.
That is it.... I am moving to Texas... I cannot believe you guys are getting so much rain! We have enough of our own dust here... we do not need any more from the Saharan Desert! That is one big dust plume!
Drew, I am glad that the resident looking for Mr Miller was not more insistent.... could have been an exciting moment. I am glad that you have support helping to get your next phase of life in a reasonable assembly of order.
Wng, I hope that you can determine what is causing Coco have her symptoms. It is crazy prices of pet food and minimal regulation of the ingredients that caused us to start making our own dog food. It is cheaper than the cheapest kibble, but top notch ingredients. We have been doing it for 14 years now.
Did not do any trim in the hobby shack yesterday, but prepped all the materials. Decided to make the storage shelves vs. buying racks. Then took it to the next level deciding to in-lay the shelves into the wood supports. So, spent the day in the shop making dados, sanding, and staining the shelf structural supports. This project has broken out way past a simple shed.... But, if you are gonna do it... do it good....
So... getting myself in gear... time is a wastin’ ....
Everyone have a great day!
   / Good morning!!!! #114,270
Thomas, nice (well really great) job on the bucket guard! Looks factory installed!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2008 GMC Sierra 1500 Ext. Cab Pickup Truck (A56858)
2008 GMC Sierra...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
JOHN DEERE 624K WHEEL LOADER (A58216)
JOHN DEERE 624K...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
