MF 1528
/ MF 1528 #1
Mike65
Massey Ferguson 1528
Can anyone tell me how to use RTV silicone on oil pan. I have removed old material, sanded lightly & cleaned with alcohol. Applied RTV & hand tighten bolts, let dry for 24 hrs & it is leaking.
/ MF 1528 #2
Hand tightened? They generally don't need to be overly tight, but hand tight is not enough.
In the past I have run a bead around the perimeter, and also circled around each bolt hole. Tighten to torque spec.
/ MF 1528 #3
You did well with the initial hand tightening. Hopefully that allowed the RTV to form to all the gaps. I hope after letting it dry you proceed to tighten it as RJ suggested above. An oil pan is not a hand tight thing.
/ MF 1528
Yes, I did tighten bolts, but it still leaked. What kind of RTV is best?
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
8ft Fork Extensions (A66734)
8ft Fork...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
2021 CATERPILLAR 308CR EXCAVATOR (A65056)
2021 CATERPILLAR...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
