Rattle Can
   / Rattle Can #1
TexasBoy
Gold Member
Central Texas
Kubota M7060HDC12, L4600DT, Ford 4000
Can you guys recommend a good 'Ford Blue' in a spray can? Also for the correct 'white' that is used on the wheels? Touching up my '65 4000 !
Thanks in advance for any info !
   / Rattle Can #2
I use VanSickle, from my local farm supply.
   / Rattle Can #4
Haven't found any that don't fade but then so did the factory finish. They all seem to work good enough for a functional work machine.
If you wanted to do a "look at me" restoration I would get a color match from an auto paint store and do a base coat, clear coat paint job.
   / Rattle Can #5
I'm not a fan of rattle can jobs. The paint fades and does not last.
For touch ups or even big areas I use a brush.
Get a 1 1/2" china bristle brush and have at it.
Takes two coats usually and I add a wee bit of thinner to the second coat to get it to flow better.
Here's a couple of photos of brush jobs I've done on my own 4000. 20180405_064640.jpg20180405_064626.jpg20200228_114806.jpg
   / Rattle Can #7
Here's a couple of photos of brush jobs I've done on my own 4000.View attachment 659964View attachment 659965View attachment 659966
A pressure spray gun works best, though a brush can be OK for some items.
   / Rattle Can #8
   / Rattle Can #10
There are several blues, depending on year. Gotta be careful. '65 uses more of an aqua blue....little green in it and somewhat lighter than '63 and '88, both of which are blues, nearly the same shade. White isn't white, it's Ford Light Grey. Van Sickle for me too.... TSC and Atwoods farm store handle it here. As good a sun resistant rattle can I can buy.
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
2012 GMC SAVANA BOX TRUCK (A51243)
2012 GMC SAVANA...
Quick Attach Pallet Forks (A47384)
Quick Attach...
John Deere 455G Loader (A48837)
John Deere 455G...
