Polyethylene seem welder
/ Polyethylene seem welder #11
I am not sure it would work on mesh. Material to material contact might be unpredictable. A flat surface has 100% contact. How strong a joint is required?
/ Polyethylene seem welder #12
Would need a guide to squeeze the mesh into a 3/8” or 1/2" wide area to ensure contact between all of the strands.
Aaron Z
/ Polyethylene seem welder #13
I have a feeling it would not work. Often plastic is welded with high frequency energy, but I don't have a clue how that works. But sounds expensive.
/ Polyethylene seem welder #14
It would probably have to mash/melt on a gradual angle to the clean cutoff edge to insure a wide welded area rather than a typical hot wire line. > instead of V
/ Polyethylene seem welder #15
The fact, that I have never seen such a mesh welded, makes me question the validity somewhat. My tye-rap idea wouldn't work?
The price is reasonable, doesnt need to be strong as the mussels grow into the mesh within a few days which supports their weight. Worth a try, I wonder if it would be possible to increase the temperature as the mesh may require more heat than a polyethylene bag
If it takes any more time than simply tieing a knot then there is no advantage. Plus it would just be something else to pick out on the processing line.
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2012 PETERBILT 367 (A60736)
2012 PETERBILT 367...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
UNKNOWN TANK MANIFOLD (A60736)
UNKNOWN TANK...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
