B7500 Front Axle Help
/ B7500 Front Axle Help #1
gtbensley
NH
Bobcat 753, Bobcat MT55, Case CX36B
Morning,
I have a B7500 HST with a 302A loader which has recently started to leak gear oil from the front axle. I know I have a leak from the top seal on the portal axle and I do know how to fix that one. My second and more serious leak is coming from the pivot mount where it bolts the axle to the chassis.
I have watched BX series videos on how to repair these but can find zero information on how the B7500 axle attaches and seals.....although I can say it looks a bit different from a BX. Anyone have insight on how to remove the front axle and what seals needs replacing? Is it a massive pain? I bought this used and havent located a shop manual yet for it, but its on the list. Is this an identical axle to the B7800? Simply curious, haven't found info on that either.
I appreciate the help, thanks.
/ B7500 Front Axle Help #2
Buying a shop manual is the answer, so I'd work on getting that soon.
SR
Agreed, was just hoping someone would have some personal insight on the issue.
I will be calling Messicks to see if I can get a manual and seals.
/ B7500 Front Axle Help #4
I dont think that pivot has gear oil behind it. Dosnt it have a grease fitting? Could you be seeing the engine front crank seal leaking?
Going from my b8200 front axle.
Thats how my b7200 was, but this definitely gear oil and it's coming through the mount which goes through the axle. It's the same spot the driveshaft enters the axle as well.
/ B7500 Front Axle Help #6
From Messick's, here is how the axle mounts:
Aaron Z
Wow thanks! Can I ask how you got that from messicks? I am looking currently but can't get any digrams up.
Looks like it's a pretty simple o ring design. Shouldn't be too bad to get apart.
/ B7500 Front Axle Help #8
Just look for the parts at Messicks, you'll probably have to register, but then they email the pdf to you.
/ B7500 Front Axle Help #9
Setup an account on there website and you can see the Kubota parts diagrams, you can also install their app and see parts diagrams that way (that is how I pulled up that diagram).
Aaron Z
Got it....I hadn't made an account. Thank you for the help, I appreciate it.
/ B7500 Front Axle Help #11
I have a B7500 and have replaced those seals . The first time I did it the seals were damaged . The second time I lifted something heavy and some dirt got it to the hub and would not let the oil seal do it's job so I just had to clean the hub out without replacing the seal .
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
2017 Ford F-150 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
Informational Lot - Financing (A63688)
Informational Lot...
