Woods BH750
/ Woods BH750 #1
92wrangler
Kioti lk3054
Hey everyone, I'm having issues with my bh750. I got it in pretty rough shape, I changed the oil and filter and it was mostly water. I got everything moving except for the boom. If I set it down, it wont pick back up without help from the dipperstick but if I push down I can really feel some down force even all the way extended. It also seems that there is little force in the swing, at least swinging left, i tried pushing a railroad tie and it didn't even budge it. Most of the cylinders leak a little but not enough for it to droop without leaving it for a day or so, I meant to rebuild them but I want to make sure it's worth putting my time into. I'm not sure where to go from here, does this seem like it could be an issue in the valve at the operator or something failed inside the cylinder? Any help is greatly appreciated, thanks.
/ Woods BH750
/ Woods BH750 #4
I would go with the valve and/or the relief pressure valve stuck.
My first thought was to check the plumbing coming from the tractor. And supply pressure.
They can be hooked up backward and still work. If something up stream is still open (like the 3 point) the hydraulic pressure will go to that function then divert to the tank rather than power beyond to the backhoe lines.
I had one with the swing chain. It was always touchy!
/ Woods BH750
Hmm I'll have to check those out. I think it's time for me to buy a gauge set up to check actual pressure and verify its proper direction.
/ Woods BH750 #6
Is yours plumbed into the system or does it have a separate pump running off the PTO? I ruined the pump from my last BH when I hooked it up backwards to run my wood splitter.
At least it wasn't the pump in my tractor.
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
New/Unused AGT Flail Mower for Excavator (A61166)
New/Unused AGT...
1820 (A62130)
1820 (A62130)
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
