Sihl starting
   / Sihl starting #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Any tips for getting a Stihl saw to start quickly when cold. We have two and both need about 40 pulls to start, doesn't matter if it been a day, or a month sitting in the shed. Start well warm, run like a dream and work great but that initial cold starting is a pain. Any thoughts?
   / Sihl starting #2
How old are the saws? Always been that way?
I have a couple older stihls 024 & 034 and never had one issue with starting. Put the switch to choke, probably 3-4 pulls until they fire once, then click it up into run one more pull gets it running.
   / Sihl starting
Heck they are both over 10 years old and both have always been that way. Always thought must be a trick or something i'm missing...
   / Sihl starting #5
I had a gas Stihl that was like that unless you sprayed with starter fluid into the air inlet. Oh, this is after refilling it. ALWAYS run it empty.
Now, our MSA-120 is no problem starting. Just pop a battery in and push the button. Same for 2 Kobalts before it.
Ralph
   / Sihl starting #6
Part of the issue has to to with the starting operation change. the older Stihls would start and run a couple seconds on choke before you either popped the choke off and kept running or it died and you turned the choke off and then restart the saw. A lot of the newer saws don't completely start. They will poof/pop around the second or third pull, and if you miss the poof the next pull will flood the saw. With the newer Stihls I never pull more than about 4 times without turning the choke off because that means they are already flooded.
   / Sihl starting #7
Try putting a new spark plug in it. A husky I had did the same thing. A new plug did wonders for it.
   / Sihl starting #8
Dont forget to clean the exhaust screen. If you run the premix too rich the screens get gummed up. Carb cleaner works well. Also keep you air filter clean.
   / Sihl starting #9
Generally that's what works for me on my MS290 Farm Boss.....10 year old.
Cheers,
Mike
   / Sihl starting #10
A new plug can only help.
I turn the choke off after 2 or 3 pulls even if the motor didn't pop. Then they often start after two pulls on 'run'.
2007 Chevrolet Uplander LS Van (A55853)
2007 Chevrolet...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2005 Ford Taurus SE Sedan (A55853)
2005 Ford Taurus...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
2015 Nissan Versa SE Sedan (A55853)
2015 Nissan Versa...
