How would you [safely] take down this tree?
   / How would you [safely] take down this tree? #121
Throw a good heavy duty strap around middle of tree above that 3ft. stump then pull from far away as you can with tractor the OP has...see what happens.
Sheesh!
   / How would you [safely] take down this tree? #122
Trees and ladders are a terrible combination. I壇 go with the throwing the rope and pulling it down approach.
Thrown a chainsaw in the mix and you have a disaster.
   / How would you [safely] take down this tree? #123
Thereç—´ still stuff too big and thereç—´ places too steep to send a machine down even on a line.View attachment 656770
One of the smaller snags that got left on that job.
Not to mention operators who don't know what they are doing...
   / How would you [safely] take down this tree? #124
If they’re on a line there’s some rules that require a certain amount of experience in extreme situations. For fallers I wish the US would adopt the BC falling standards.
   / How would you [safely] take down this tree? #125
So why were you shooting the pine cones off? Jon
It was for a USFS program that was finding and propagating better trees. The idea is that the seedlings that got planted after logging or a fire would be the best available, not just random junk that looked like a tree. The program had been going for many years before I worked for it and is still going.
you do realize that a rifle round can travel more than a mile, and kill someone when it comes down, right?.:shocked:
Yes. National Forests in the Sierras extend for 40-60 miles and butt up to the next National Forest to make a chain that's hundreds of miles long. There's very little private land and nearly all of it far was away from the parts we worked in. Unless there's a recreation area of some kind, the only activity is logging. We knew nothing was going on down range. It's probably not something you'd be able to do safely in a lot of eastern forests, or where I live now for that matter. I wasn't suggesting it for the OP, just telling a story.
   / How would you [safely] take down this tree? #126
Thanks for the explanation. Jon
Well, I hate to bring this thread some semblance of closure, as there have been some interesting side topics, but the tree is down, and I'm alive.
As most suspected, it didn't take too much to get it down. I got a chain right up on the hinge joint, so it would rotate out of the snag on the other end, and then attached it to my tractor so I could pull at 90 degrees. I put 2 25' lengths of chain, with the power puller in between, on it to get as much length as possible. I didn't want to pull with the tractor due to the possibility of exceeding the strength of the line on the power puller, and having stuff flying around. So, I just cranked on it (the handle is designed to bend before the rope breaks) and it came down quite easily.
Once down, I put a chain around the butt of it and pulled it out.
Thanks for all of the advice. When doing something for the first time it's always nice to be able to get advice from others that are more experienced. IMG_20200530_145917.jpgIMG_20200530_150102.jpg
   / How would you [safely] take down this tree? #128
:thumbsup: Gooder-un
   / How would you [safely] take down this tree? #129
Good deal... although there are some who will be disappointed that the thread didn't break the records currently held by the drain plug and pallets-in-field threads.
(Actually, after recent suggestions I was hoping to see pics of explosives bringing it down. :firecracker:)
   / How would you [safely] take down this tree? #130
I was hoping some mysterious holes would appear with no trace in the dust.
2011 Ford F-250 Ext. Cab Reading Service Truck (A55788)
2011 Ford F-250...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2019 Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55788)
2019 Diamond C...
2006 Ford F-150 Crew Cab Pickup Truck (A55788)
2006 Ford F-150...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
