Pitman arm remover perhaps works a bit better and avoids damaging the rubber boot. Obviously Hydraulic lines both supply and return need to come off to allow split. I guess you have done that.
Rubber boots are done anyway, have as free on order
Think it's okay to spray down the inside of the bell housing and then spray paint?
Current pics of the rebuild
Ford rehab - Google Photos
Also... how easily does that release bearing come off? do I just use a puller?
My ford is 2 wheel drive so I don't have what you have. On my Kubota and many others, you have fill plug on top, a level plug on the side and drain on the bottom. You will drain first, keep the tractor on level ground, open the level hole and fill from the till the oil comes off the level hole. I can go to NH and check but I gotta get some ZZZZs can check tomorrow if you can't find it.
Man, that thing did not wanna go back together. I kept fighting getting the studs in the bell housing aligned, and aligning the 4wd driveshaft, got it up tight and held tension with ratchet straps, then gave it a little hammer lovin, and everything fell into place.
I don't have a NH around here, but I'll look at the front differential in the morning, I know on the very front of it there's a zerk, but not sure what else is going on there. Busted the fuel sediment bowl trying to get a new filter in :fiery: so I gotta grab a new one of those...
Drained the hydraulic fluid, and there was some milky greenish goodness ( Shared album - Cody Croslow - Google Photos ) in there. Going to get her all back together, loader and all, and run it for a day or two before draining some of the hydraulic fluid, and seeing if it's clean or not. Pics updated in the album posted above. You were totally right, that hydraulic filter was diiiiiirty.
One more question if you don't mind... Is there an easy way to tell when the hydraulic fluid is full? I haven't pulled the filler cap off yet, but I'm assuming there's a dipstick? the manual says it takes 5.8gal of Hydraulic fluid, so I guess I'll just empty a 5gal in there, run it for a few minutes, and then check the dipstick?
