Good morning!!!!
   / Good morning!!!! #112,753
Nice photos guys ... :thumbsup:
79F and partly cloudy here but actually very pleasant outside right now.
Ran by the hardware store mailed a letter and picked up a couple of fittings to mount the last two bluebird houses, then headed in for the grocery pickup (looks like they got it right this time), then over to Pet Supplies Plus to pick up cat food and treats ... only it turned out that the order was at a different location (there are 3 of 'em within 6 miles of the house) so I ran over there (stopping to fill the van up with some cheap diesel on the way) ... guess I should not have said ok to "allow Safari to use your location" when I placed the order - as it appears that it changed my normal store ... :rolleyes:
Then back to the house and unloaded groceries and cat food/treats. The Squeak appeared disappointed it was not the large, industrial-sized treats however.
After that I installed one of the fittings and put up the third bluebird house.
Oh ... and before I left I loosened up the gland nut on the left (leaking) curl cylinder, removed it from the tractor, and took it up to the garage along with the pins ... :thumbsup:
   / Good morning!!!! #112,755
Drew more prayers sent you are one strong fellow soon this will pass and you should be good as new. Be well my friend
   / Good morning!!!! #112,756
Tail of dragon on our list of things to do
   / Good morning!!!! #112,757
I haven’t driven the tail, but would like to. Some of my motorcycle buddies like to ride it.
   / Good morning!!!! #112,758
   / Good morning!!!! #112,760
Nice sunset Rip.
The latest findings about covid19 that came out in Medscape today.
* Mounting evidence covid19 is transmitted via aerosol transmission and the importance of wearing a mask.
* Vaccine timeline realistically is 12 to 18 months away.
* One study found almost 1 in 3 people with COVID-19 imaged using bedside echocardiography had right ventricular dilation.
* Add "fibrinolysis shutdown" to hypercoagulability as a possible blood-related complication of COVID-19
* Front line health care providers many could face an increased malpractice risk. Doctors may be practicing outside their specialty and across state lines during the pandemic, for example, which can present issues. Nurses may be particularly vulnerable.
* A positive antibody test, in many cases, makes it about 50/50 that a person actually has any antibodies against the coronavirus.
COVID-19 Daily: Airborne Transmission, Vaccine Timing Doubt
ELECTRIC PIZZA WARMER (A58374)
ELECTRIC PIZZA...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
