Should I hack the back end of this sucker off, or no?
   / Should I hack the back end of this sucker off, or no? #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
Previous owner welded a hitch receiver tube on the bucket. Personally, I've yet to move a trailer with it, the only use I had for it was wrapping ratchet straps around it for lifting stuff. Looking to add hooks for that purpose, regardless.
Anyways, I'm not thinking to remove the whole thing, but am considering cutting off the back end of it. It hasn't really gotten in the way of anything as of yet, it just flat out irritates me the way it looks.
Anybody have any input on why I should NOT cut this thing down? I thinking maybe there's some application I haven't thought of where a longer tube would be beneficial.
   / Should I hack the back end of this sucker off, or no? #2
I have one long enough to get a pin in and that should be all you need. Maybe 5" overall. I use mine for A BALL for GN trailer moving and to hook straps to.
   / Should I hack the back end of this sucker off, or no? #3
I'd just take a cut off wheel and cut it completely off if you aren't using it.
Save it and make yourself a 3pt trailer mover or use it on your ballast box.
   / Should I hack the back end of this sucker off, or no? #4
I woulds weld a reinforcement strap around the corner of the bucket top, then cut off the tube behind the strap.
Bruce
   / Should I hack the back end of this sucker off, or no? #5
Worthless for moving trailers, could be use with receiver D-ring or hook adapter, otherwise I'd lose it.
   / Should I hack the back end of this sucker off, or no? #6
I agree, cut it off and pull a trailer if you have to with the 3 point hitch, its a lot safer.
   / Should I hack the back end of this sucker off, or no? #7
View attachment 657006 View attachment 657007
Or try this.
   / Should I hack the back end of this sucker off, or no? #8
   / Should I hack the back end of this sucker off, or no? #9
Scrape metal I had...1/4" x 2" ID sq. tubing weld tabs on the side used 3/8" bolts thick 1/2" washers to fasten.
   / Should I hack the back end of this sucker off, or no? #10
You gonna Chuck Norris that or use a saw? :)
657007d1590348967-should-i-hack-back-end-img_20200524_110544-jpg
2020 JOHN DEERE 245G LC EXCAVATOR (A52707)
2020 JOHN DEERE...
Harrell 3605 (A50123)
2012 Chevrolet Silverado 2500HD (A56858)
2012 Chevrolet...
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
2015 Cheverolet Tahoe SUV (A55853)
2015 Cheverolet...
5' MOWER (A52706)
5' MOWER (A52706)
