My Little Green Goblin Garage
   / My Little Green Goblin Garage
Nice job! Thanks for sharing. The extra work on adding the hip roof is a nice touch. Looks very nice.
Thanks.. I really like a hip roof, definitely more work cutting the rafters but I like the looks, and it matches the Cabana you can see in the background in some of the pics.
Ok , time for installing siding. I have it all cut to length, stained both sides and all edges so its just a matter of getting them plumb, spacing properly and nailing them up!
So this process goes pretty quick once you get everything cut to size and stained.
You'll notice in the third pic the drive through door on the end has turned into a walk door , but... keep watching.:rolleyes:
   / My Little Green Goblin Garage #33
:thumbsup: Nice place to hang out for me time. ;)
   / My Little Green Goblin Garage #35
like the color, coming together quickly now.
Ok, door time.. (and this isn't in real time, this was actually over the course of several months)
Getting started.. Old school..
Both done
Waiting for stain to dry..
Fitting and hanging the doors.. not too bad considering the building. Had to adjust a lot of stuff due to the uneven and sloping concrete, but it all turned out ok.
   / My Little Green Goblin Garage #38
If your John Deere is the “ Little Green Goblin “ would than make my big Kubota “ The Great Pumpkin “ :confused::laughing:
Maybe our tractors can go Trick or Treating together? :D
If your John Deere is the Little Green Goblin would than make my big Kubota The Great Pumpkin :confused::laughing:
:thumbsup: That's a biggun!!
I have the orange one too, but nowhere near as big! Does most everything I need it to do... mostly...
So this project is completed other than running electric in and installing circuits. A very satisfying project seeing as it all started with standing trees on my property, cut them down, ran them through my little samill to make the lumber I needed. All the wood on this building was from the property other than the OSB on the roof, and the plywood on the soffits. This is my first "big" project I've done with the rough sawn lumber, I know its not big, but at 64 and working by myself its rewarding.
And if you notice, on this end of the building there is now NO door, started with a drive through door, then a walk door, but I want this building mainly for storage. So after much thought during the building process I eliminated the door completely so I could install full width shelves for more storage..
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
Kubota ZD21 Zero Turn Mower (Diesel) (A54865)
Kubota ZD21 Zero...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
2011 Land Rover LR4 4WD SUV (A55758)
2011 Land Rover...
