What is cylinder liner protrusion on Y485?
/ What is cylinder liner protrusion on Y485?
Torque is good. Compression is normal. Pressurized water to 20psi. Copious water vapour in #4. Tore apart and pushed out the swirl chamber splice blocks. Inside #4 was oily carbon with no sign of water. #1 was dry light carbon. Cleaned it up and inspected it carefully. There is no crack or flaw in there. So, that seems to rule out a cracked head - there is nowhere for compression to get to water passage other than through the fire rings on gasket. I am back to pointing at the gasket not sealing.
Liner protrusions are 1.5 thou, the deck is dead flat, the head is flat. The 395 book says protrusion should be 2.75 thou to 5.9 thou. All I can try now is shimming the liners up 3 thou if I can find someone to make them.
Thanks. Good to know there is a backstop if it comes to that. I did search high and low on your website.
try a double gasket, see what happens, I don't see complete sealing on the head to gasket interface.. you did tighten the head bolts to the proper sequence, using the proper torque, right?..
Given how this gasket has metal fire rings crushing on liner protrusion, I dont see how two gaskets could work. First I'll try old school copper sealant and pump up the torque a bit. If that dont hold, ill try two. What is to loose?
I did torque correctly, new dry bolts, thread chased holes, measured depth, etc etc etc
/ What is cylinder liner protrusion on Y485? #25
I'm not saying don't do it, it's just that you are would have two soft fire rings together. Plus decreased compression, and these are compression-ignition engines.
It always helps the draw-down to torque in steps (maybe you did that). First step is 1/2 the total torque value in sequence, then full torque in sequence.
/ What is cylinder liner protrusion on Y485? #28
What was the thickness of the fire ring, or did you check that?
/ What is cylinder liner protrusion on Y485? #29
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
UNKNOWN TANK MANIFOLD (A60736)
UNKNOWN TANK...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A59230)
2008 Ford F-550...
