What is your opinion of this dealer installed option?
   / What is your opinion of this dealer installed option? #11
I really don't see a problem with it depending on what the OP is doing with the tractor. It is hard to tell but if that is where the output ports are, there may not be any other option. It does look like the shield is pretty tough.
The tractor house pic's appear to have the same set up from what I can see. Maybe I am missing something.
If that's where the lines have to be then maybe this isn't the right tractor for the OP?
   / What is your opinion of this dealer installed option? #13
Purchased a BX23S last week and scheduled to be delivered tomorrow (Wed). The dealer installed the lines inside the rear wheel well. Not sure if the pics shows it clearly, but the lines and shield reduce the clearance by more than half. Is this the correct? Would you accept this? Thanks in advance.
Are these parts a K_ubota OEM kit etc? or was it a custom fabrication application ??
   / What is your opinion of this dealer installed option? #14
I'll side with SDT. He is a Kubota tech btw.:)
Actually, I am not and never have been a Kubota tech.
I am, however, a retired design engineer, lifetime mechanic, etc.
SDT
   / What is your opinion of this dealer installed option? #15
It is my understanding that this is not the Kubota supplied third function set up.
SDT
   / What is your opinion of this dealer installed option? #16
I agree with Oosik , SDT and others. This is UNSAT for a brand new machine. If you do not care about mud, crud, ice, etc. lodging up in there and you will never ever put chains on the rig -- to each his own, you may not care. Mr. /pine raises a very good question: Is this the std Kubota kit installation or it is a homebrew by the dealer? I would bet, as SDT said, it is the latter. At very least I'd discuss the "WHY?" with the dealer before accepting it.
   / What is your opinion of this dealer installed option? #17
My 2380 has the same set up. Must be what they do. I figured some of it was for the Kubota third function the dealer installed. The shield appears to be steel and installed Very firmly
   / What is your opinion of this dealer installed option? #18
Tractor House has lots of pictures. It looks like lines are run differently (to me).
2017 KUBOTA BX23S For Sale In Chesterfield, Michigan | TractorHouse.com
https://www.tractorhouse.com/listings/farm-equipment/for-sale/192326341/2017-kubota-bx23s
Nope. Same
   / What is your opinion of this dealer installed option? #19
Neil Messick just did a video on these. Pretty sure that is where they are supposed to be.
   / What is your opinion of this dealer installed option? #20
In reality, there is no wheel articulation so the clearance remains constant. I'm curious if the OP took delivery or refused it....
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2007 PETERBILT 385 CAB AND CHASSIS (A58214)
2007 PETERBILT 385...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
404 (A52706)
404 (A52706)
2018 Generac S/A Towable Light Tower (A55973)
2018 Generac S/A...
