John Deere 110 loader backhoe, no power to fuel shutoff solenoid
   / John Deere 110 loader backhoe, no power to fuel shutoff solenoid #1
fishinfool
Member
Trying to troubleshoot no start issue on JD 110.
Fuel shutoff solenoid is not clicking "on" when key is turned to "on" position.
Replaced Fuel module at fuse panel, still not getting power at plug going to fuel shutoff solenoid.
Tested solenoid, it works.
Hotwired the solenoid in place, it clicks, tractor fires right up.
One theory at this point: PTO circuit may be engaged (in spite of PTO switch off) telling solenoid not to open.
How to check? PTO shaft lurches a bit when cranking engine over, is this normal when PTO not engaged?
Any other safety, fuel shutoff override switches i should be aware of.
Open to any other suggestions, tractor is on a remote, fly in only ranch, id like to be more prepared on next trip to troubleshoot/fix
Thanks
Doug
   / John Deere 110 loader backhoe, no power to fuel shutoff solenoid #2
I'd suggest getting the service tech manual for the 110 TLB
Thanks been,
I致e never worked on one of these tractors, doubt I値l ever see the opportunity to work on another.
Investing in a service manual may be the smartest approach - and leave it with the machine for the next guy.
Would have also given me reason not to post my question on this site which has proven to be a wonderful source of knowledge and learning.
In short, if you have nothing helpful to contribute, please don稚 bother to reply.
Thanks,
Doug
   / John Deere 110 loader backhoe, no power to fuel shutoff solenoid #4
Sorry, but that was the most helpful I could be. Wish you good luck.
Thanks Been,
Probably good advise,
Sorry for being such an ***
Thanks
Doug
   / John Deere 110 loader backhoe, no power to fuel shutoff solenoid #6
I can send you a .pdf manual if it helps.
   / John Deere 110 loader backhoe, no power to fuel shutoff solenoid #7
It may be a small link ( can’t remember what it’s called) that controls the amperage to the solenoid. High amp to pull in and lower amps to maintain the open position. A ten dollar part. If full amperage is constantly applied to the solenoid it may burn out.
For interest the solenoid may activate the injection pump but does not shut off the fuel. Don’t know if this applies to your loader.
On my 4200 JD heating and tapping on the solenoid while working the priming pump usually works when there is no click.
   / John Deere 110 loader backhoe, no power to fuel shutoff solenoid #8
Egon may be thinking of the thermister.. ?
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
2016 Dodge Caravan (A50324)
2016 Dodge Caravan...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
