how to keep a knot from tightening too much when lifting something
   / how to keep a knot from tightening too much when lifting something #21
Some other ways to connect straps:
Joining Two Slings
There again by using those knot types you are drastically reducing the load capacity and compromising the slings integrity. That procedure is not condoned. When you take a rigging course like I have you,learn all this stuff and they have examples of failed straps due to various knotting methods. Large shackles are the only proper answer. When you see pictures of heavy loads dropping due to failed straps it is a wake up call. Conversely for us on TBN not at our full time jobs; we will not be picking loads we have to worry much about either weight or height from the ground. As a construction worker though safety becomes a habit that you do not break, even at home or the farm.
Times when I was assigned as a safety inspector it was not uncommon to find a whole gang box full of straps that had seen better days. It cost more to send them out for load testing than to replace them. When condemned we painted the loops red.
Old Navy Boatswain Mates can tell a lot of sad stories about failed rigging.
Ron
   / how to keep a knot from tightening too much when lifting something #22
The running bowline has the anti-tighten quality of the bowline plus it will tighten up on whatever you tie it around.
I use a bowline quite often, especially when the rope will be used for lifting when it is under water. It comes apart easily when wet. But I have never used the running bowline.......
So the squirrel comes out of the hole, between the limbs and back into the hole? Interesting, I'm going to try it today.
   / how to keep a knot from tightening too much when lifting something #23
Ron
Yes, I have taken rigging "courses" and I have worked in machine shops that depended on extensive rigging. The one shop we used straps from 1" wide to monster 16" wide by 1.5" thick. Also, we used about every type of lifting chains out there. We machined parts from a hundred pounds to 120 tons.
If you are using a 4000lb strap to lift 300lbs, I think you are fine on compromising on the knot type being that you are well within the capacity of the strap. Sometimes, a person has to safely improvise.
   / how to keep a knot from tightening too much when lifting something #24
. . . for us on TBN not at our full time jobs; we will not be picking loads we have to worry much about either weight or height from the ground. As a construction worker though safety becomes a habit that you do not break, even at home or the farm . . .
Ron
Depending upon the type os steel, shackles may have a safety margin of 4X or 6X (Safe Working Load or Working Load Limit or Maximum Securing Load is 1/4 to 1/6 of the Breaking Strength). This allows many (of us) to "get away with" bent, worn, or otherwise unsuitable devices a knowledgable inspector would reject. Be aware that big box stores often market their lifting or lashing materials by breaking strength. A competent rigger automatically de-rates mild steel shackles and rings by half, chain and web lashing by half, (re-used) wire rope and fiber rope by 2/3 (i.e. SWL = 1/3 BS). According to a pamphlet I have from a cordage company the hauling strength of a bowline is 50% of the tensile strength of the rope, a bowline on a bight is 60%. Note this is for round, laid (twisted) rope.
   / how to keep a knot from tightening too much when lifting something #25
Don't let this happen to you.
Bruce
   / how to keep a knot from tightening too much when lifting something #26
I like using shackles with staps/chains. Nice to have half a dozen on hand.
   / how to keep a knot from tightening too much when lifting something #27
There are lots of knots that don't jam under a load. Ashley's bend and the similar zeppelin knot come to mind.
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A57192)
UNUSED LANDHERO...
DIRT DOG APP48.3 (3) SHANK 48" SPRING TOOTH HARROW (A57192)
DIRT DOG APP48.3...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
