Good morning!!!!
   / Good morning!!!! #111,581
TBN just stripped out all the carriage returns!
One you use the edit function you loose the carriage return from now on even on an original post. It will not even let you put more than 1 spaces between words.
   / Good morning!!!! #111,582
Testing carriage return on iPhone.
To see if it works.
   / Good morning!!!! #111,583
Eric, I have not given the hot railings much thought. Aside from going to pick them up from my recycle material stacks.... I had a very hard time being able to hold onto them after heating up in the sun. I had to drop one set because they were burning my hands while trying to carry them to the shop....
The stair rails would be my only concern. Maybe they will have enough radiant cooling being in mid air. Maybe white paint will be in order... I will have to see how this pans out..
   / Good morning!!!! #111,584
Carriage return is working for me on the IPad... so is multiple spaces.... weird... no emojis though.
   / Good morning!!!! #111,585
wngsprd the ky31 is coming along right now better than southern lawn extreme but it was planted sooner
   / Good morning!!!! #111,586
Good morning - 45 going to 64 today. Very cold for this area at this time of year. Going to be around 34 Friday night.
Got the oil changed on the chipper last night. Moved the toolbox out a bit using standoffs on the tractor. Fixed a missing bolt on the Lawn tractor and added a lock washer and loctite since it's the second time I've lost that bolt. I'm sure I will hear it some time soon as I run over it with the mower running.
Drew - how are you doing, any bites on the farm?
I hope they fix the TBN issues soon. no emojis, no pictures.
Stay well and be safe.
   / Good morning!!!! #111,587
45ーF and clear skies this morning, going up to 69ー today. Rain predicted for overnight and into tomorrow, and temps are going to get down into the mid-30 tomorrow night. I guess we can't say we didn't get a Spring season this year.
Edit: Looks like the quick edit function isn't working right either.
   / Good morning!!!! #111,588
56 this morning, 65 later, cold this weekend. All the rain lately has been good for the grass, I mowed at six days Monday, and might have to mow by the weekend.
Not much on the agenda but some things that need doing, so I’ll see how that goes.
Ellen is taking off next week and we are going to try and finish her 70 El Camino, it would have been done last summer but I got sick. Not much left to do, finish some skimming on the roof and put the new vinyl top on.
Have a good day. God bless.
   / Good morning!!!! #111,589
54F @ 10:30, with mostly sunny skies. High predicted to be 63F and windy this afternoon. Currently under a "Pollen Alert".
Extended forecast predicts below normal temps until next Thursday. Chance of rain on five of the next ten days, and a chance of snow Friday night into Saturday morning.
Grass will be growing like mad ...
Might try and locate the two house wren houses out in the garage today and see if I can get those cleaned up while I'm on a birdhouse refurbishment roll ...
Probably also get the oil and filter change done on the Kubota while it's nice out. Grease the FEL and pull the blades off the MMM while I'm at it.
Have heard the Eastern Phoebes calling but have not located their nest. Doesn't appear as though they have nested under the deck as the typically have done in the past. Might just be too early.
   / Good morning!!!! #111,590
Toppop hopefully you will share a picture or two so I can drool over it
   / Good morning!!!! #111,591
good morning guys. Got home late yesterday, sucking down a lot of pills. Renal insufficiency aka adrenal failure, life threatening per head doc, unknown cause other than stress related.
Liasion from hospital called, old army nurse, guy was great, lots of big city experience with renal failure, very helpful, asked if I felt awful and hurt a lot... yup
Said best thing to do was calm my body, apparently primary connection is stress. But I'll be on cortisone the rest of my life. Could have been much worse.
Ted, your work is wonderful, you must be proud looking over your accomplishment.
I'm going to bed with my kindle. Ohmmmmm.
show goes on, showing Sat morning
   / Good morning!!!! #111,592
David, consider your wife's statement a compliment..You actually use your truck...and look at all you have gotten accomplish. Badge of honor...
   / Good morning!!!! #111,594
Drew - relax-maybe some calming music.
   / Good morning!!!! #111,595
65°F and .26 inches rain. Remnants of some sort of front in area so not sure what that means. Hoping it means I can put on brush hog and mow outer areas.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #111,596
good morning guys. Got home late yesterday, sucking down a lot of pills. Renal insufficiency aka adrenal failure, life threatening per head doc, unknown cause other than stress related.Liasion from hospital called, old army nurse, guy was great, lots of big city experience with renal failure, very helpful, asked if I felt awful and hurt a lot... yupSaid best thing to do was calm my body, apparently primary connection is stress. But I'll be on cortisone the rest of my life. Could have been much worse.Ted, your work is wonderful, you must be proud looking over your accomplishment.I'm going to bed with my kindle. Ohmmmmm.show goes on, showing Sat morning
Well, we're glad you're still above ground!!!
   / Good morning!!!! #111,598
Maybe not best of news, but really good to see you here 🤙
   / Good morning!!!! #111,599
Thanks, Drew.
Of course after I got truck back to white I told her she was now doomed to wander the parking lot as she wouldn’t recognize truck.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
iDrive TDS-2010H...
More info coming soon! (A56858)
More info coming...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2844 (A58376)
2844 (A58376)
