Kubota L3710 Tierods, repair vs. replace???
   / Kubota L3710 Tierods, repair vs. replace??? #1
Blackgreyhounds
Palmyra, PA
Kubota L3710 HST
I just replaced the front tires on my L3710. I was thinking this would be a good time to repair or replace the tie rods. Both have small bends in them as you can see in the pictures. Dealer is quoting > $800 for OEM replacements. Is it possible to just get them bent back to near straight or replace with aftermarkets? What say you all?
   / Kubota L3710 Tierods, repair vs. replace??? #2
You can press them straight again, But they might not be as strong . Did you get a price on aftermarket ones?
I couldn't find aftermarket yet, but haven't looked very hard. Where could I look for aftermarket? Where could I find someone to press them back? I.m just a Harry homeowner, so I don't have a press, etc.
   / Kubota L3710 Tierods, repair vs. replace??? #5
260. 00 something each on Messick's website you just need the long end...Is the short end bent also?
It's funny you quote Messick's. I live <10 miles from them. I called today and got the $800+ quote from them. Then, I found the part numbers myself and looked them up on their website and got the same prices you got. Yes, I only need the long piece on the RH side. Not having any luck looking for aftermarket parts yet.
   / Kubota L3710 Tierods, repair vs. replace??? #7
I looked also, found nothing....
   / Kubota L3710 Tierods, repair vs. replace??? #10
Once you have the part number use google to search for the part number.
I have a JD and the tie rods from JD are $317.00 (each). I found aftermarket parts at <$70.00. But, there aren't many suppliers out there, other than JD, I only found 2 other suppliers.
Most any machine shop should be able to straighten them. I had a 1-1/2" square bar that needed to be straightened. Took it to a machine shop and cost me $25.
71050 (A49346)
71050 (A49346)
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
2010 International 4300 2,000 Gallon Water Truck (A49461)
2010 International...
MAGNUM PRODUCTS 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
