Valve ID
/ Valve ID #1
Tejas
Hondo, Texas
NHL185, Kubota B7100
Need some help!! I have a post driver/post pounder, it is on a SS Q/A mount and currently is connected to my Skid steer. It runs a single acting cylinder...lifts up the weight, and move the lever the other way and it drops it. This valve is leaking, slowly. It appears to be leaking out the back, where the little plastic(?) piece is. Would there be a replaceable O-ring there? I realize there are tons of types of these valves/spools... anyone know what it’s called? I have a scissor lift that I’d like to run off my machines hydraulics, instead of batteries... would be awesome to put a similar valve on.
/ Valve ID #3
Probably a quad ring as opposed to an O ring, least ways any valve I've had apart is, not saying they're all the same :)...........Mike
/ Valve ID
Thanks. I will look into that
/ Valve ID #7
Carefully remove the screws holding the cover on. Depending on how the valve is made there could be an O-ring held in place by this cover or you might have to pull the spool part way out of the valve body to remove the O-ring. You won't know until you take it apart. All we can do is guess by looking at the pictures.
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
PALLET OF APPROX (10) SCISSOR LIFT CONTROLLERS (A62131)
PALLET OF APPROX...
2020 14ft. Continental S/A Boat Trailer (A61569)
2020 14ft...
Mama Goat Decorative Statue (A61569)
Mama Goat...
2017 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2017 Ram 1500 4x4...
Wooden Wagon Wheel Rocker (A61569)
Wooden Wagon Wheel...
