Attachment for installing pipe, wire
/ Attachment for installing pipe, wire #1
Taters525
Member
Port orchard wa
None
What's the best attachment for installing pipe and wire so I don't have to use the backhoe and dig trench. Looking to run irrigation lines about 12 to 18 inches deep but also running electrical 18 to 24 deep.
/ Attachment for installing pipe, wire #2
The best attachment for installing pipe and wire is a trencher.
Renting a Toro Dingo with a trencher will cost you much less
money since investing in a small trencher will cost you a
small fortune.
A Toro Dingo will give you a flat trench to lay the pipe and wire in by the way.
Unless you plan on buying direct burial cable you will need to install it in schedule
80 conduit with bell ends and glue it together. the other thing is its best to bury
the conduit and pipe in sand to prevent damaging the irrigation lines and wire.
/ Attachment for installing pipe, wire #3
That deep, look into renting a trencher. Doubt you would have enough repeated use to own one.
/ Attachment for installing pipe, wire #4
I may be mistaken but I believe schedule 40 electrical conduit is adequate and has belled ends. I think schedule 80 is usually threaded like galvanized. I've always used schedule 40 for wiring. Use a size or two larger than you think you'll need. It makes pulling wire easier and leaves the possibility for adding more later.
/ Attachment for installing pipe, wire #5
Probably a CAT D6 or D8 with Vibraplow....
Dale
The Hayes product is the exact kinda thing I'm looking for. Will have to do a little research it says for 70 to 100hp tractors and need to make sure it will lift high enough. I'm more in the 30 to 40hp range. I did see that land pride has a single shank ripper that's fairly long but no attachment for installing pipe in it. Pretty sure I could bend something up and weld it on to work after looking at that one
/ Attachment for installing pipe, wire #8
You are correct. However, I would not go larger than 2-1/2" on electrical conduit, most boxes for residential use don't accommodate anything bigger and getting an adapter to convert between 2.5 & 3 requires many parts and is very expensive. There is a conduit fill chart that shows how many and what size wires will fit in a conduit, I try to stay with half that number for ease of pulling. Usually schedule 40 is used underground and schedule 80 is above ground (normally used to run up poles or buildings to provide extra protection). However, my electric Coop says schedule 40 for running up to the meter box is fine. But for the pipe running up the pole they put in metal pipe. I recommend that all joints be glued, it makes it easier to get the pull cord thru with the vacuum cleaner approach.
/ Attachment for installing pipe, wire #9
For ground engagement 24" is really really deep. Be sure you do plenty of research on this if you plan to use a ripper approach.
Again, do your research on what kind of power it will take to drag that ripper thru the soil at 24" deep, or for that matter, even 12".There is a reason these multi ton, multi function units that the utility companies use to bury cable also include a small backhoe in addition to the vibratory plow.
/ Attachment for installing pipe, wire #11
/ Attachment for installing pipe, wire #14
If you have rocky soil....good luck. Subsoiler works ok in sand and clay. Wouldn’t work for me in idaho. Impossible to go 18” with trencher. Need excavator
PALADIN JOHN DEERE 524-70" WHEEL LOADER FORKS (A62129)
PALADIN JOHN DEERE...
BUNDLE OF ASSORTED LUMBER (A62131)
BUNDLE OF ASSORTED...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
