   / Harbor Freight Tools that don't suck #13,241
Mine isn't (as other posters know). The oil fill on the Portland corded pole saw is about the diameter of the end of a toothpaste tube...lol and it don't hold much, maybe 1 fluid ounce at most. Very limited oil capacity.
I will say the motor seems to be powerful enough though. Powers right through limbs, no issue. Not sure the cordless ones have that much gumption but then I don't know never have had one to compare.
My cordless has tons of qumption (new word for me)
HT 13 Pole Pruner | Professional Pole Pruner | STIHL USA
   / Harbor Freight Tools that don't suck #13,242
The HF battery powered one is actually very good. The motor is strong and the battery lasts longer than I do. I had an oak tree where I used it to cut 8" branches up so I'd rate it pretty high. And the oil tank apparently is bigger with a bigger cap because I can fill it from a gallon jug.
I assume you’re describing the Lynxx 40 volt pole saw? I’ve got the pole saw, chain saw, and the leaf blower. I use the pole saw a lot for trimming up lower branches on oak trees for clearance for tractors. I also use the pole saw for cutting down cedars. I can reach in and notch it in the direction I want it to fall, the cut backside until it goes over. The battery life is very good and use of Oregon bar and chain is a plus.
When I got my 40 volt chain saw it leaked oil bad. I took it back to the store, for an exchange, and the manager told me to keep the battery and charger so .. I now have a spare battery.
I keep some bar oil in a mustard container .. flow is very controllable. I also use a similar mustard container for blue marker dye for sprayers.
   / Harbor Freight Tools that don't suck #13,244
Most likely 3 times the price of my HF Portland. I can deal with the small fill port for the price.
Probably more like 8 times the price..
   / Harbor Freight Tools that don't suck #13,245
I assume you豎*e describing the Lynxx 40 volt pole saw? I閾エe got the pole saw, chain saw, and the leaf blower. I use the pole saw a lot for trimming up lower branches on oak trees for clearance for tractors. I also use the pole saw for cutting down cedars. I can reach in and notch it in the direction I want it to fall, the cut backside until it goes over. The battery life is very good and use of Oregon bar and chain is a plus.
Yes, Lynxx 40 volt pole saw, and I like it well enough that the string trimmer is on my list for the next time I get to HF.
   / Harbor Freight Tools that don't suck #13,246
If you are going to spend that much, may as well go the distance and get a real one.. just my thinking..
No "real ones" available anywhere near me that I could find. I was not going to buy one that I couldn't lay hands on first. I was able to actually lay my hands on one of these, and liked what I saw. It also helped that they had a sale on the Hercules model right when her old saw bit the dust. With the sale going on, the price difference was about $100. I liked the Hercules enough better that it justified the extra cost for me.
As mentioned, it suits my wife's needs just fine (she has made furniture and cabinets with it).
   / Harbor Freight Tools that don't suck #13,247
No lowes or homedepot or anything like that?
   / Harbor Freight Tools that don't suck #13,248
I have all 5 of the Lynxx tools. The string trimmer is only one I would not give a five star to. String trimmer does not auto feed new string like it should. I used all 5 tools today.
   / Harbor Freight Tools that don't suck #13,249
I've read that it works better if you throw away the string and restring it with better quality line.
SKID STEER ATTACHMENT TILLER (A58216)
SKID STEER...
GORILLA 2 WHEEL CART W/ HAND TOOLS (A58374)
GORILLA 2 WHEEL...
2015 FREIGHTLINER CASCADIA DAYCAB (A58214)
2015 FREIGHTLINER...
2003 Big Tex 10PI...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
New/Unused 7ft Work Bench (A57454)
New/Unused 7ft...
