LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,220
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
The BRAND is going to have very little to do with the quality of the service that you get.
The seller or dealership is going to be the factor on quality of service.
Also, something to think about when you have a routine service done to a tractor it is the same as having it done to your car or truck.
You will NOT get the most experienced and best mechanic in the shop doing your oil change and lube job.
You WILL get the greenest most inexperienced junior man in the shop, if you are lucky someone may check over his work.
