Pole building or metal building
/ Pole building or metal building #21
Our Morton building was built in 2007 other than faded shutters no problems
/ Pole building or metal building #22
I'd be interested in your quote. I had a Hansen builder quote me $35K for my 30x40x12 barn.
I'll let you know what I hear later today, I am going to be pricing something close to 2000sqft with 12 foot walls as well. Besides an overhang and a few windows I am looking to keep pretty basic.
/ Pole building or metal building #23
I have a couple windows in my pole barn, and wish I didn't. They only added a little expense, and they improved looks from the outside, but I hate that they waste wall space when I need it. They also add potential leaks. If I was doing it over I would add clear panels along the top of the walls, or maybe not even that. With LED lighting, I find myself using the bright lights most of the time anyway.
/ Pole building or metal building #24
Wall space is something to consider, not too worried about the leaks.
/ Pole building or metal building #25
I have a Morton 36x42x14 nice building but you pay for it .........
/ Pole building or metal building #26
39 years ago, I had my Morton built with NO WINDOWS!
No windows, means that no one can see in, and no one can break in.
/ Pole building or metal building #27
Per my phone call to Hansen about the steel used:
"Our typical is 29 gauge, but we do have 26 gauge available also".
Morton steel is 19 gauge!
Anymore questions?
A cheap pole barn is just that....a cheaply built pole barn!
When the high winds come through, your pole barn will be scattered across your neighbor's property.
/ Pole building or metal building #28
Anymore questions?
Huh? 2 years ago, our area suffered a severe hail storm. Morton buildings roofs were damaged right along with other building suppliers roofs.
/ Pole building or metal building #29
Of course they were!
I'll bet Chevys, Fords and Chryslers were equally hail damaged too!
What is your point?
WIND DAMAGE!
WIND DAMAGE!
Not HAIL DAMAGE!
Are you suggesting that 29 gauge steel has the same resistance to twisting and tearing as 19 gauge steel?
Perhaps you should take some time to visit a strength of materials lab.
/ Pole building or metal building #30
What is your point?
WIND DAMAGE!
WIND DAMAGE!
Not HAIL DAMAGE!
Well! DON'T LEAVE THE BLEEPING DOORS OPEN DURING A WIND STORM!!!!!
/ Pole building or metal building #31
One point not mentioned here is insurance. If you will have to have it insured or want it insured the pole building may cost more due to the wooden post and frame. Just get price on that also. Depending on what the building will be used for you will want it insured so check that also.
One reason I stopped with hay when I did was the need to build large hay barn and at my age did not feel it smart. Almost all hay barns here are pole barns. You have to be careful in comparing the specs on some companies for in some states there is little regulations on a "farm building" so it is more a buyer beware deal. Tornados hear are rare but hurricanes are not. Termites are not rare at all. If you go pole barns of course you will use treated post but treated post where drilled for rebar in concrete will allow termites in past the treatment...know too well on that. I agree the pole barn just feels warmer, more like a farm building. For my use of a hay barn the poles do not extend as far into the building. If using any kind of loader may want to consider that. Know two friends with Morton buildings, they are fine buildings. Do insulate the roof as have been recommended.
/ Pole building or metal building #32
I have this on all my barns from Morton....Dry-Panel is applied directly to steel panels at Morton's manufacturing plants during the roll-forming process. The specially designed fabric traps moisture as it condenses and releases it back into the atmosphere through normal evaporation when conditions allow works great in my shop the only water drips are off the sky lights the plastic roof type.....
/ Pole building or metal building #33
Our building has survived 60mph plus winds just fine and a derecho no damage
/ Pole building or metal building #34
Of course doors should be closed in any sort of wind.
A roof covered with 29 gauge steel is a wind risk with doors either open or closed.
/ Pole building or metal building #35
Anymore questions?
Morton's steel is 26 gauge, noted on their website. They use a lower tensile steel but thicker. Some others say their 29 gauge is tougher since they use high tensile steel. I'm not sure if one is better than the other for all scenarios (wind. hail, etc). But there are also some lower grade materials used by some... lower rib heights, and gauge of metal "after painting". Those are the real dangers.
/ Pole building or metal building #36
I WAS WRONG!
Morton does use 26 ga. steel.
/ Pole building or metal building #37
I WAS WRONG!
Ha, that happened to me one time too. :D
I wasn't trying to point out you were wrong but that there is more to the material than just the gauge. I remember years ago I went though this, and researched several of the options. That's when I came to the conclusion as long as I chose one of the better quality names I was relatively safe. But boy there are some questionable materials sold by some.
/ Pole building or metal building #38
I got a quote back for a 42x48x12. (2) entry doors (2) 10x10 garage doors, all insulated. (4) windows and insulated roof- 70k.
Fully insulate the interior and finish the inside with plywood and acoustical steel, 88k.
/ Pole building or metal building #40
I had the roof on my house, garage and barn replaced this fall due to hail damage. All were asphalt shingles. My chicken coop had 29 gauge roofing on it. The only roof that showed no hail damage was the metal roof on the chicken coop.
For my pole barn kit, I paid a little extra to get 26 gauge steel on the roof and walls instead of the standard 29 gauge. I will also be decking the roof with plywood to deal with the interior condensation issue. Plus it protects the metal roof in case of branches falling etc. I've seen roofs without decking get punctured clean thru whereas metal with decking simply dented but did not puncture.
